So Guys I LOVE my FJ40 but VERY frustrated with my Intermittent Startup issues - hope you can help.
A bit about my FJ40
- New Batery, Cables, Sparkplugs, Startup coil (Internal Resistor).
- Stock Carb (to my knowledge)
- Stock Distributor (to my knowledge)
- Has the Evaporative Emissions Control Device and is connected as described here ('72 FJ40 Emissions Control Device~Advice - https://forum.ih8mud.com/threads/72-fj40-emissions-control-device-advice.551434/)
- I use 89 Regular Gasoline
Here is my Startup ritual (this is what has given me best results over time):
If Cold (Has been sitting for over 8 hours):
- Pump Gas 2 times Slowly (in and out)
- Choke 1/2 way
- Crank: I hear the Carb Solenoid, Carb Window shows Gas (about 3/4 full), Engine turs (the whole thing shakes)
- if it Turns on (About 50% of times): Joy, then push choke back in as idle stabilizes
- If it doesn't turn on: Push choke in, Wait 5-7 mins, and try to turn on as if it was hot (See below). Usually turns on, if not,,, wait another 5, repeat.
If Hot (has been shut off for less than 8 hours):
- Crank - Starts every time, EVERY TIME.
Here some of my desperate attempts to fix the issue:
- Drained the whole Gas tank and filled with fresh new Gas. Maybe some old gas and water - no changes.
- Treated Carb and Gas with SeaFoam. A can on the Tank, A can on the Carb Throat - did get some good results in terms of accel response and a better idle.
- Desmoged the thing for a few weeks and seemed like it was behaving SO MUCH BETTER - Startup rate went up to average of 80% of times. But now is back to the same Intermittent Startup behavior.
Desmoged like this:
- Connected Distributor Diaphragm vacuum directly to top of the Intake Manifold
- Connected Carburetor Diaphragm to bottom of Carburetor (Port looking towards the left hand drive Drivers Fender)
- I have 2 more larger Vacuum hoses that I have not messed with:
- One going from Air intake to Top of Valve Cover.
- One going from Base of Carburetor to Engine Block on the Passenger Side.
What Am I doing wrong? Does my Fj40 hate me?
- What Should I be checking? The thing runs Beautifully, supper Strong (if it turns on)...
Here What I've been thinking on doing:
- Rebuild carb.
- Desmog and Convert to Weber Carb.
- or?
What do you guys suggest? let me know if some pics would help? or?
A bit about my FJ40
- Choke 1/2 way
Desmoged like this:
- Rebuild carb.
- or?
