- Joined
- Jun 6, 2005
- Threads
- 74
- Messages
- 1,388
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
I just read through the whole thread. Since the coils are the same on both sides, that's definitely a huge issue. The designers must not have been aware of the regular difference on all land cruisers, and it gets worse the more it's lifted.
I would suggest buying 1 of each of these 30mm spacers and putting them on the low side.
exitoffroad.com
exitoffroad.com
When you add 30mm to the low side, it will shift some of the weight over to the other side, lowering it, and it "should" balance out then.
Dobinsons Front 30mm Polyurethane Coil Spacer (Single) Toyota Land Cruiser 80 105 - Exit Offroad
High Quality Polyurethane, maintains height over time Perfect fit between OE isolator and coil seat Sold individually, available front and rear for several vehicles Lasts longer than rubber Easy to add lift height for worn coils
Dobinsons Rear 30mm Polyurethane Coil Spacer (Single) Toyota Land Cruiser 80 105 - Exit Offroad
