Builds I’m the 2nd and 4th owner (1 Viewer)
Were you able to get dellow to fix the ring gear on the flywheel or did you get it done somewhere else?
This is exciting. 1UZ the world!
I haven’t had any dealings with Dellow. I purchased one of their bell housings and clutch kits from the classifieds here on mud.
The seller also included a flywheel.
The flywheel that showed up is for a boat 1uz and won’t accept a clutch.
I’ve since ordered one from:
I see. Hopefully that clutch/pressure plate works with that set-up.
Did you do a dyno yet?
I’ll be eliminating the stock coil/igniter combo on the 1uz. The haltech likes 3URFE coil on plugs. Luckily other lesser model toyota engines use the same coil packs. I was able to get 25 of them for $100. I also ordered some studs from Toyota that makes them a bolt on affair.
And now a moment of silence for all the Toyota’s and scions that gave up their coil packs for my projects.
I’m going to see if I can make an adapter plate to mount off the Oem 1uz Bellhousing that will allow an h series trans to bolt on. This would eliminate the need for an expensive and difficult to source custom housing.
Looks like that engine is walking to its new home on its own😆
Any pics of the injectors installed?
I’m using a magic wand.
The injectors will mount in the new lower intake, which I’m still waiting on to arrive from 🇦🇺 .
I have been thinking about using the 100 series stuff but a 5 speed would still be my preferred way to go.
Yeah this is looking good!
:popcorn:
following for updates.
