Hood scoop pics! (3 Viewers)
I used a STI scoop from Ebay for 118 bucks and then some rover knock off vents ( had to fill the "sport" script in)
more than a 20 degree drop in temps while it's been in the 90's here.... well worth it IMHO.
the RR vents fit perfectly in the location i have them without cutting the hood bracing and they were cheap.
forgot that I actually got the STI scoop on Amazon...
Amazon product ASIN B00IGZPPSI
I have a 2004 wrx sti hood scoop I was planning to install on mine at some point - $100 with a free pickup or add $5 and I'll ship it. Same as above (same color too - PSM)
I just pop the hood... it drops approx. 5° on hot summer days over 100°
But hood vents in rear coners of the hood is tempting. I am more intrested in droping intake temp without a snokel but vents would help intake temp also i assume.
Anyone in this thread know how important the framing of the fzj80 hood is? Can it be cut into? I have some vents but the slats in the vent drop down below the mid point. See photos. Not sure if it will work to use these vents. If hate to trim them...and would be willing to cut the hood open if the frame is not super important. Bummer, I was under the impression that these vents lay flat on the hood.
I will be watching this because I was looking at these exact vents
Looks like @Hoosier Daddy did the same kit. Maybe you could PM him and ask about it. He's on this same thread on page 2 or 3
Ordered the trackspec kit. Can’t decide on doing the center or not. Thoughts?
I like the way it looks. The side driver vent is right above the fuse box. Will this be an issue?
First post ever, build is well under way so I thought I would finally share.
Thanks for reading!
1992 Fj80
Did you remove the frame from the hood? Did it have any negative effects? I just got the exact same louvers. Thanks in advance for any help you can provide 🤙
I installed these a while back. I cut the supports and re-bonded the factory brace. I also added an aluminum brace in the back. The vents actually add a bit of bracing back into the holes. Here are some pics...hope it helps.
Yes! Save my life dude. Thank you 🙏 I figured they would add a little bit of bracing back but I definitely will go with the additional support like yours. Well done dude 👏 No negative effects you can see from cutting?
