Are you gonna replace the rest of your freeze plugs with brass?
Your 5th glow plug is part of the glow controller system of the super glow setup.
It is used in series as soon as the the glow light go's out on My 1981-84 BJ 60s, (3 of them so far).
First stage is the both main solenoids relays close on key on engine cold (haven't done temp readings on the sensor to the FSM yet) to the 5th glow cable wire , and also the 2 separate wires feeding the buss bar. after a few seconds to (time // temperature) the first relay opens stopping power to the wires that feed the buss bar , and then the currant only flows through the 5th glow plug of the glow controller that is in series with the other 4 plus that are in parallel.
This keeps the 4 glows plus warm and the controller (5th) heating the intake manifold air as it controls amperage to the 4 glows .
Good system , just need the controller box to work the system .
I mentioned this before in another post , but was told there's no such thing.
so i guess it's just us two now.
As with frost plugs / freeze plugs , seeing it has a block heater , Im leaning towards someone use coolant / antifreeze that should have a clean internal cooling system, if you see lots of internal rust , and the rad came out with brown water, then I would have a real close look at the plugs. Problem the plugs are also in the Cyl head machining jackets , and there's the real crappy ones to replace. There also much thinner in material. They are a separate part #'s from any kit I've seen. I have replaced a few of mine only.
Your Oil cooler cover looks cracked from a freeze , and I would replace it. the gasket for it is available , but from that cover to the cooler member itself i used Teflon covered metal gaskets , turbo shops have them as large drain gaskets. Those were NLA.
The sludge should be cleaned out if your thinking of doing a re-bearing of the crank , and I would check the oil piston cooling valve , one of mine had a bum gummed up spring , that on hot idle let the oil pressure drop. The setting of the cooling valve is 2 bar. (so @ 2bar and less it closes ,oil squirters stop squirting).
VT
Good luck on your engine.
Hey Dan, if you are pulling the superglow stuff, can I have some of it as a backup for my system? Would make it worth your while! Shop time maybe!?!?!
