I also made a mount for the CB in between the spreader bars in the overhead. Like I always do, I welded on captive nuts. I hate sheet metal screws or having to use two hands just to take a bolt off.
I will make a similar bracket for a 2M HAM radio too, just forward and "underneath" the CB.
And here's how this will tie into the frame:
These will be welded onto the frame, and then a bar will run from the plates under the body down to these bushing/bolt combinations. That way vibrations from the frame are isolated from the body, and the arms are removeable.
So, aside from that I just did some odds and ends. Mostly I bled the fuel system after getting air into it yesterday when I hooked up my fuel lines without a tight hose. And of course after that was done....
I know I said I'd probably do this. And I did. Front driveshaft? Check. Steering? Check. Working clutch? Check. Brakes? Not so much. But our shop is in a little bowl almost so it's possible to do this without getting TOO scary...
YouTube - Driving the 40, sort of...
And after I had proven to myself that it could be done (and I turned the truck around just because I could) Mom was up unloading some metal and discussing a little welding project for me, so I had to show her too, and she took a video of the same little maneuver from outside the truck. Also, I honked the horns.
YouTube - Turning the 40 around
I'm waiting on brake parts from Toyota before I can get the front brakes working (I need new pins and retaining springs), but when those get here next week--I think I will at least take it around our little private driveway a little.
Tomorrow I'm working on that little welding project for Mom (building a rack for a solar system), and hopefully finishing up the wiring on the 40. I got distracted by the cage today.
Dan
