Freds40 builds a 60
Just looked @ his site and it dosn't look too promising. Did you try Now serving ? It's been a couple of months since I got mine from him. I've heard he is a 1 man shop and does this on the side from his full time job.
BTW, for the sake of ease of install and time, I threw my clutch fan and shroud in so I can get it running and wheel it a bit. After I've driven it a while, I'll throw the Taurus fan and DCcontrol in.
I will take a look there. I've heard his stuff is great and does exactly what I need but the reviews are mixed. Sounds like he delivers but it takes a while.
Truck looks good! :beer:
I will be very interested to see if you get that Taurus fan to fit. I've got a new one just lying around and I'm looking for more cfm than my Contour fan pulls (which is more than adequate 98% of the time but I recently found the 2%). However I'm having trouble seeing the depth of the Taurus fan fitting with the water pump snout. Of course I've got a 62 with the tranny cooler which it limits where I can position the center of the fan...
I threw the Taurus fan in and it will fit. THe fan motor is off center and if I turn the whole shroud upside down, the motor sits off to the passenger side of the water pump pulley. Should be pretty easy when I go to do it. Just a little more time consuming than I need right now.
You have a sponge on your antenna... :D (Teach you not to be home when I come by)
Call me when you get a free minute...
Chris:cool:
Carved up the front fenders so I could turn the tires.
And took it for a spin around the block today. There is still quite a bit to do and there were a few issues to tend to but it's definately getting closer. :bounce2:
1 more.
I like the look of no front bumper.
If you get a chance would you mind measuring from the ground to the bottom of your frame rail? Yours looks lower than mine did with the 39.5s.
nice work... mine was about 28-29" at first. It dropped to 26ish when the springs settled and I thought the balance wasn't too bad and the pucker factor was at least predictable using the stock springs. I ran 2" spacers in the front and 1.5 in the back.
:smokin:
