Freds40 builds a 60 (1 Viewer)
Barbie does make a nice addition to the shop. Gives me the sense that you're in touch with your delicate side.
BTW Nice build! I've been following it since you started it!
Thanks. I'm happy with the progress so far.
BTW, it's Cinderella...........................my daughter hasn't discovered Barbie yet. :rolleyes:
My DC Control showed up today
It'll run my Mark VIII fan
Does the Mark VIII fit with a 2F in the stock location? I tried to fit one on my 3FE but it look like the depth of the fan motor was going to hit the pullery of the water pump. Went with the twin Contour fan instead with a DC Controller (which is working very well).
WOW super cool ... but you might have to trim the fenders some:cheers:
The fenders are pretty clean so I was thinking about resetting the locks in the steering box so it'll stop before the tires rub. Turning radius will suck but I'll look pimp @ the mall...........................................:lol:
No, I actually got a new air saw that I'm itching to test out. Should make short work of the sheet metal. :bounce:
I cut 3 or 4 in outa mine :doh: and used 15x12's to get that wide
nope... it'll be way cooler then that, keep guessing :D
The range box already had a 4.7 and is set up to bolt to a 465. the rear of the tcase will get tossed.
way to easy
yes...yes I am :D
It's best solution to cruiser rear axle's I've ever heard.
nope,
think bigger
Nope, you'll just have to wait and see...
You need a hobby. :lol:
BTW, don't you have a plane to catch?
