but replaced the fuel pump and relay. They wanted to replace the Fuel Pump Resistor but apparently the part number is 23080-50170 is discontinued, this part puts out 0.97 ohms. Doing some searching the earlier models and 2006 landcruiser use part number 23080-50061 which produces 0.73 ohms. Why would Lexus change the ohms mid production and would this contribute to the stalling at idle? Just a curious observation, any thoughts?
If the fuel pump model # changed mid 06 and all of 07 yet this just happened on a cherry 07-it's probably not the fuel pump, right? You would think if the "new" pump is still having these issues that it's got to be some else. Has anyone who wrapped their fuel lines been able to replicate the issue yet?I recently did a trip from So. Cal to Colorado in my 2006 LX (68k miles all dealer serviced) and experienced the same stalling issue. Ambient temperature was over 100 degrees and when I hit road construction in Cortez CO the car died at while idling, same happend on the return while stopping in Las Vegas.
Long story short I just got the car back from the dealer who couldn't replicate the problem, but replaced the fuel pump and relay. They wanted to replace the Fuel Pump Resistor but apparently the part number is 23080-50170 is discontinued, this part puts out 0.97 ohms. Doing some searching the earlier models and 2006 landcruiser use part number 23080-50061 which produces 0.73 ohms. Why would Lexus change the ohms mid production and would this contribute to the stalling at idle? Just a curious observation, any thoughts?
I don't have any of these issues on an 06 Lx 211k miles but eventually I'll climb a hill on a hot day. Is everyone just replacing these as part of pm now?if you drive around with the carpet up you can hear the pump cycle. Yes I'd ground the resistor, but I'm sure that will trigger a code.
You could also move the pump ground, and relocate the pump positive if you're thinking (rightly so) that there's no way you're getting alternator voltage at this pump.
Much drama about this on supra boards from long ago.
Thing is, this pump is probably 200% adequate for this job. Checking real voltage at the connector would be a good thing (while driving open loop 80mph on the freeway)
Paul has probably, maybe, watched this pump run out an open tank?
I have on accident. Ten 20 year old frat kids couldn't drink beer that fast.
Interesting idea. IDK how to do that, do you? I'd only do short term as a test. Since driving like that too long, would likely overheat pump further.Would jumping the resistor not be a simple emergency fix - and also proof a weak fuel pump if symptoms disappear? It would also increase the return flow and keep the fuel manifold temperatures lower on hot days.
It's not a bad idea. But you can wait until first time you've a shut down.I don't have any of these issues on an 06 Lx 211k miles but eventually I'll climb a hill on a hot day. Is everyone just replacing these as part of pm now?
"Manifold Temp" Are you meaning cylinder hard temps?
I'm convinced the factory pump in the 06-07 which is a smaller Denso than past (98-05 Denso and Aisin fuel pumps) years, has a defect. They get hot and resistance builds, pump slows, and then engine runs lean. Often stalling as pump switch back to low speed VIA relay reducing volts/AMP. Put in a new fuel pump and cleaning up battery post/cables/wire block and all works fine. Just pump resolves issue. But one's asking for issue, if battery area and grounds not serviced also.
Did you go yeith oem or the Denso pump? If you go Denso do you also have to purchase the fuel filter "sock"? Not thr fuel filter in engine bay.FWIW after changing out my 2006 pump to new one I no longer have this problem in at least in the last few hot months and with towing.
Pinching off your return fuel line sounds like a great way to leak fuel out of your injector seals and burn down your vehicle and garage.Interesting idea. IDK how to do that, do you? I'd only do short term as a test. Since driving like that too long, would likely overheat pump further.
One other thing may be to pinch off return line. This increase fuel pressure in rails. If RPMs go up, it's a clue of low fuel pressure. Which is likely fuel pump and or fuel pressure regulator issue(s).
But usually with these 06-07 fuel pumps. That by just engine shutting down (stalling) and waiting a few minutes. They fire back up. So we tend to just drive without further ado!
I've one now we're trying to get ECT (engine coolant temp) down. One thing we're going to try is a new fuel pump. It had a crank no start, after a heat soak (boiling fuel). It's possible it's running lean at times due to heat soak and high outside air temp (OAT). Thinking is, heat increasing resistance in wiring and pump motor. The shutting down, may be clue of a bad fuel pump during heat soak. Slowing flow and pressure of fuel delivery to rails/injectors. Causing a lean running condition (hot cylinder head temps). Also fuel heating, may also reduce fuel delivery to cylinders, as molecules expand. Also adding to lean condition.
I did run pump by cranking engine with fuel line off filter. But it was not a heat soaked condition. I didn't measure volume either and didn't have issue with that fuel pump. It was on the Unicron. I now know, why it had gunk buildup at fuel hatch door. Engine CAT were overheating and thus so was fuel. I found the radiator fins badly clogged and suspect coolant was low for a long time (20K miles in one year). Engine got so hot, hoses disclosed and plastic melted, even the block was disclosed. I now know the gunk under the fuel hatch door, was sign of fuel boiling. Once I had it all back together. I test drove, it had no fuel pump (factory pump) issues or and any other.
But today I've a better understanding of the fuel pump issue in 06-07. As such I'm inclined to recommended replacement of fuel pump proactively.
What I see as they heat up, from running in it's high speed (engine pulling vehicle up a hill does this) typically on a hot day. They fail and engine shuts down, as pump relay drops power to pump for lower RPM low pump speed. It's not the relay but the pump itself that fails.
Wire starting at battery post and grounds, I do feel have effect. After all, corrosion and age increase resistance, reducing AMPs to fuel pump. So age certainly is a factor.
But my first experience with these 06-07 fuel pump issue, was in Snowy when brand new. PO (one owner) had complained from mile ~1. Toyota Dealership tested and tested, again and again over next 95K miles. Even had pressure gauge and tech stream hooked up and w/service manager, shop froman and mechanic (master) in the vehicle. Drove to into mountains to recreate and could not find any issues. They keep testing fuel pump time and time again. Finally for some reason, they just tossed in a new fuel pump. History showed the next 100K mile after new pump installed, and AFASIK, still works today without issue.
To test pressure of these fuel pumps, is usually not going to be revealing. The best test is in real word on a hot summer day.
Few tip when replacing fuel pump:
Relieve fuel pressure, by disconnecting wire block under DS passaged door and frame rail, crank engine, disconnect battery.
Hose off top of gas tank, once body access hatch under seat removed.
Replace tank seal at top of pump assembly.
