ok, which port is it?Yes.
It depends on what year engine you are talking about.ok, which port is it?
fj40 1977It depends on what year engine you are talking about.
Here's how i did it on an early 2F without an oil cooler...fj40 1977
nice adaptor,,thanks, i didn't know about those threads,, i would have jammed a regular 1/8" pipe in there probablyThis…
Amazon product ASIN B08LQN61K6
…along with a standard Autometer mechanical oil pressure gauge and fittings and the OEM low pressure sensor in the stock gauge location to get to this on the motor…
…and mounting the gauge using existing holes under the dash (so it can be removed for full return to stock without additional “PO” holes) to get to this in the cabin…
…allows the existing OEM pressure gauge (in this early ‘63 it’s a low pressure light in the cluster) to remain functional.
But maybe this is an insegrevious post since we’re talking a 2F and not an early 1F. But I got to show off a bit.![]()
thanks,, totally didn't know that.Not so fast. I believe that the threads are BSP ( British Standard Pipe). McMaster-Carr sells a BSP Tee then you can buy an adapter to screw on a NPT fitting. I have all the part numbers if you need them.
That's why Mud is the best!! If you don't know, just ask the question. Most likely its already been done.thanks,, totally didn't know that.
That's the same adapter that I bought a few months ago, it works perfectly.nice adaptor,,thanks, i didn't know about those threads,, i would have jammed a regular 1/8" pipe in there probably
