Doing some research here and can’t find anything on this subject via search.
Early 60s, before the transmission spacer was added, have a shorter front driveshaft with a CV joint at the t-case end and a single u-joint at the diff. Later 60s with the transmission spacer have a longer “regular” driveshaft with a single u-joint at both ends.
So my question is this: were the axles different to accommodate the different driveshafts? For early 60s you’d want the diff pointing up at the t-case (to get the u-joint aligned with the driveshaft angle). In later 60s you’d want the diff flange parallel with the t-case flange, roughly level with the ground (maybe +/-2*). The caster spec on both is +1* however.
So we’re early 60s “clocked” differently, like in how the knuckle balls were rotated at installation? Maybe the stock suspension was low enough in stock form where they didn’t worry about it.
I have heard 62s did have the diff pointing upwards more. I don’t know any of the reasons why that would be (A440 longer than the H42?), but it shows Toyota had this on their mind at some juncture in the design process.
Curious minds want to know…
