just for arguments sake:
I could see a lower max temp rating making the material too soft but doesn't it also matter the type of adhesive used? If it's a 500F material but the same adhesive, they will both fall off at the same rate. The stiffer material might be more likely to move than one that gets softer.
There's been several different tests using various types of sound dampener. It's simple, cut up a few chunks, stick them to a piece of metal, and shove it in an oven for a few hours.
Back when Sounddeadenershowdown.com was a comparison site (before someone bought it for a sales site) Damplifier and another one (can't remember the brand off hand...) were the only two that didn't fail at least partially. There's been more than one test on that, see the link above where frootloops reproduced the test with Damplifier and eDead.
I do know that sticking a small piece on the backside of the sheetmetal makes a difference and you don't need to cover the entire sheetmetal. Just enough to change the vibration of the metal- that's what Toyota does with it's sound deadening.
That's true and it helps, but the difference between covering all of the sheet metal and just a little patch is night and day.
I did my wifes truck with just Spectrum, applied approx 3 mm thick to the rear quarters (I test drove it before I did the doors and tailgate), and the difference was
amazing. Night and day.
At some point I'd like to get some Damplifier and go over the Spectrum, and see what a difference it makes from there.
What about expanding spray foam to fill in some areas to create barriers for sound and cancel open voids that amplify noise? Carefully used (**I mean this stuff EXPANDS-so not to blow out panels**), might be a cheap, lightweight product in conjuction w/ some other products??
That's an interesting idea. That stuff is a
very good sound deadener (probably mostly in the category of sound absorber), the only problem is that it takes a lot of space to acheive the same effect.
Back in the day lead sheets were the most common used sound deadening material, the problem there is that it's
heavy (not to mention toxic).
Now-a-days the material to use is MLV--Mass Loaded Vinyl. It's not super cheap and the challenge would be in applying it. It also works differently than edead/Damplifier/dynamat/etc. Their job is to reduce vibrations in the panel, MLV is there to absorb sound, so for MLV to work completely you need to cover every possible entry for sound, else the effectiveness is hugely reduced. With the vibration dampeners, you can have a small piece and it will still have a significant effect (look at the OEM dampening). If you took off the OEM sound dampening material and replaced it with MLV it would have very little effect, unless your ear was right next to the MLV.
That's one of the big challengers to the sound absorbing materials, if you have even a small gap it reduces the effectiveness drastically. Considering the design and build of a vehicle, there's too many gaps to make a sound absorbing material very effective.
