maxamillion2345
Franken-80
I like his solution the tube 90 adapters are a cool setup that makes routing cleaner and the hose shorter. Both those tube 90s are probably less restrictive than my one machined 90. Also lets you keep straight ends on the hose making building the hose less complicated, no clocking fittings pre crimp.
I have ordered up both of those fittings, I beleive the o-ring version is the pump side and the inverted flare is the toyota box side.
I was planning on using a JIC/AN -6 female 90 at both ends of the hose to screw into the two adapter fittings. Is that how you routed yours?
Also, so I don't get hosed when I go to get some lines made up, what is a reasonable cost to expect per line?
Coming out of the back of the pump I have the adapter (-6 male jic) and then I used a male female 90* -6 JIC adapter to go straight towards the hood, in a perfect world you don't really want 90* adapters in your system but whatever, then I used a small chunk of -6 hose with -6 female JIC ends on it, ran it up in a loop and came back down straight into the box. You could use whatever ends on the hose you want but it makes it easier IMO with straight fittings, easier to clock the hoses but it can be done with a 45 or a 90 on one end, more complicated when you put two 45s or 90s because the hose has a memory and you need to know how you want the ends clocked. I feel like a straight hose has more versatility for me as well, I carry a pile of adapters to adapt up or down sizes and different angles and to adapt to boss or flat face o ring, so I can always use it elsewhere on someone elses rig or whatever...
Personally I just felt straight straight was easier, and then use whatever adapter you need. There's probably an argument in there about restriction of adapters vs hose ends where adapters lose but hey, it's a give and take. If you can make a 90 on one end work for you that could work out pretty well I think and still be easy enough to clock -- just remember the memory of the hose, you probably want the fitting perpendicular to that. Okay so that was kind of flip floppy but hopefully you understood what I meant. I'll snag you a picture...
I think a short hose from the pump to the box should run you around 20$ fittings are probably a few bucks each plus hose plus time to make the hose. Adapters would probably run you I'd say 5 ish bucks each.
I took a look for -6 90's with a nice smooth radius..less restriction/heat. I ordered up two of these fittings. A bit pricey and a bit flashy, but were the only ones I could find that had that radius bend.
Aeroquip FCM3155 Steel 90 Degree Male To Female Swivel Flare Amazon.com: Aeroquip FCM3155 Steel 90 Degree Male To Female Swivel Flare: Automotive
