Builds Cruisermatt's FJ62 Build-up (13 Viewers)
Not true. Diesels have a TON more low-end torque than a 3FE. Diesels can, usually, idle down to 400rpm and pull the truck up a rock. Can't do that with a 3FE.
Ya in a f series motor you would need to keep around 800rpm. Why would u need to idle down to 400rpm? It's kinda cool u can do that, but their is not a whole lot of wheel speed difference between 400 and 800rpm, and shifting to a lower gear is always a option. On the counter side a diesel runs out of rpm pretty quick with usually 3500 rpm being redline. The biggest negative offroad for diesels is the weight. But u do get simplicity, a turbocharger to play with, and fuel mileage.
I suggest you wheel a diesel powered truck before you give advice to others about them :rolleyes: You know not of what you speak.
I like the clackity clack
Glad to report the truck is running again, haven't driven it yet but seems healthy besides a misfire at idle, but I'm going to assume that's due to ECU re-learning. Oil pressure looks good. Haven't driven it yet, waiting on a storm to quit so I can get the belts on :mad: I would have had this thing fixed two weeks ago if it wasn't for all the storms, i need to quit I breaking motors in these Florida summers !!
Also, I bought this yesterday.
Very nice rust-free roof. I haven't posted any up close pics of my current roof rust but it's baaad. This will be far easier then patching what I have.
This probably had something to do with it, filled a 12 quart container to the brim...
^^^ Damn. Was that at Hard Rock?
Interested to see the roof repair.
- Brian
I got the motor out back together last weekend, drive it about 25 mikes and parked it, it's not running right and I haven't had a chance to mess with it besides pulling the valve cover. I think I heard a knock or two as well :(
Anyways here's some photos of my roof rot on the drivers side, passenger side has some bad spots two but I forgot to get pictures of them. Also here's some more GSMTR photos
why even temp fate and get mud and grit and water in all the rotating bits drastically shortening their life span?
Well, the irony is that I normally avoid deep mud and water crossings, there was a hill climb right on the other side of that hole that I had my focus on. Broke all the rules of water/mud crossings.... later learned from locals that trucks with +50" tires don't get through that hole.
Unfortunately this isn't the first motor I've broken by being dumb.
fool me once, shame on you?...
Man you have had a rough go with your cruiser. I bet you can rebuild the 3fe blind folded by now. MIght as well go with a 305 or 350. Same fuel mileage more power. Way more power.
