Choke cable variations (4 Viewers)
Almost There .......................
1 more long shop session should be it
maybe 🤣
Custom application 1967 FJ40 w/ 1977 2F & 8/80 Late Carburetor OEM w/ Barrel
Stop style
choke cable needed application .
@Racer65 :)
This Is a Custom Job on a 1977 FJ40 2F with a Trole-Hole Updated Replacement Unit Carburetor , I am Not very
Familiar with His Product line , :meh:
But after some Basic R&D , & the Clients help also , i determined it Needed the
8/80 - Later Barrel Stop Update / Upgrade
Upon Final Post Restore / pre-shipping Lubrication Process with T-9 Boe-Shield , The New additional De-tent Stops Clicked like a Real good " Snap-On Rachet "!
T-9 Boe -Shield , by Boeing Air Lines Corporation is the ONLY product that should Ever Be considered for TOYOTA OEM Control Cable Lubrication
products like PB blaster or WD-40 will only further break down the Black Cable Liner Housing and actually cause Pre-
mature failure by attracting Dirt and Silica crystals / sand
Lets talk Bezels .............
so in the Late 1960's ( @Living in the Past will know the exact Production Date ) :)
Toyota decided to Add a Cosmetic Silver Color Trim Bezel or Escutcheon Ring to the Dash side Face of the Choke , Dash Mounted Throttle & Other Control Cables such as the V or VENT Pull Cables
at first they were made from Solid Bronze , then Chrome Plated , then at another Production Date in the MID 1970's were changed to a
Silver Color Electroplated Aluminum Metal , still looking mostly the Same in Design for the Most part
The Early Bronze Ones tend to hold up better to the Elements , The Later ones Corrode and Oxidize like a JEEP CJ7 🤣
Here are some Typical Condition Before & After Shots ,
i use a Custom Step Down Polishing Process to achieve this goal of a Mirror Like Finish .
i
Do NOT use any Polishing Compound of any kind , iv tried it and its a waist of time and makes a hell of a mess on the walls of my shop
Before :confused:
Do you have any "core" 1972 era hand throttle cables and choke cables available?
i will check for u Kurt ,
a 1972 era FJ40 / FJ55 should Have The BELL Shape Knobs , please see " generalization " examples below :
i looked hard Kurt , I do Not have any Bell Shaped 72 era knobs right now . sorry .....................
No prob, thanks for checking! Perhaps I just pull all my switches and mail them to you? What kind of turnaround?
