I have the Uniden 520XL mounted in my dash. It fits well, but you do have to get agressive with cutting stuff that's in the way to make it fit. I made it such a tight fit that it just slides (shoves) into place. It never comes loose even with heavy off road use.
https://www.amazon.com/gp/search/?tag=ihco-20
Now I also have a dual band HAM installed, but you asked about CB.
The fun part is the antenna. The radio is pretty cheap like $40. Where and how to put the antenna?
This is what I did.
To do what I did you need these parts:
I used a right angle adapter on the back of the Uniden ($10 for two, maybe you can find a single)
Amazon.com: B00NQNTQSK
A firestick tuneable FL3-B antenna ($18):
Amazon.com: FireStik FL3-B Three Foot FireFly Antenna With Tuneable Tip (Black): Home Audio & Theater
A firestick antenna spring ($10):
Amazon.com: B00042LC9M
Mounting bracket ($10):
Amazon.com: Firestik SS-174 Stainless Steel Hood/Trunk Channel Mount: Sports & Outdoors
To clear the fender with this mount you need a 'FireRing' cable ($19):
Amazon.com: B01D09WIL6
You'll need to find or create a hole big enough for the connector to go through.
So it does add up, $40 for the radio, and $60-$70 for the installation gear. About $100 all up.
Or you could do what I did and order lots of different parts that wouldn't fit until I found the above combination by trial and error!
You will also need an SWR meter to tune the antenna with, if you can borrow one, that's nicer because you really only need it once. Be aware that the plastic cover on the top of the antenna has a huge effect on SWR, so you take it off, tune it, put it on, step away and take a reading. Repeat until you get a good SWR.
This is what I did.
