I spec a fair amount of STO products. The "simple answer" I give is it's a synthetic or polymer stucco - although they do a lot more than that. There are both interior and exterior formulations. Most people generically call it "Dryvit" although that is a brand. I prefer STO over Dryvit, though.
Just a question, but is the wood framing treated at all? The pictures don't look it. I typically use treated lumber or put in a vapor barrier between lumber and masonry/concrete just because there is inherent moisture in cementitious products that can lead to rot and or mold/mildew.
Plain old tar paper works too.Definitely a rabbit hole. And I agree on the chemical issue. A simple solution I've used is a roll of the foam sill seal between wood and concrete to separate them - cheap and easy. Where water/moisture is a greater concern, there is self-stick EPDM rolls that are used for seams and repairs in membrane roofs that works well.
Parker County Texas dosen't suffer the humidity we have near the gulf coast. Not as dry as West Texas where i was raised but pleasant weather. I would almost trade the humidity and mosquitoes for upland weather and a few wild hogs.
Downside is that tar paper comes in wide rolls and you'd have to cut it down - which can be a mess with the... umm... tar...Plain old tar paper works too.
I just cut the tar paper off with a razor knife after the board is anchored. Then I use the cutoff tar paper under the next board. Doesn't seem too bad or messy. Razor blades get beat up, but tar paper cuts easy even when the blade is dull.Downside is that tar paper comes in wide rolls and you'd have to cut it down - which can be a mess with the... umm... tar...
If you have a source for narrow tar paper rolls, I'd love to see it. It would be useful.
I thought this was your house for a second.
Just climbed out of the storm cellar for tornado warning. Got me thinking how nice a home like yours would be!
N.O.A.H.We know a bunch of people who all say that they're coming to our house if there ever is another tornado here!
