Builds Benjamin’s 3D Prints Build (18 Viewers)
Ben,
Do you have any ideas for this storage area?
I have a 400W inverter that fits perfectly perfectly in there.
Did @BenCC ever respond to this inquiry? I could use the cover that goes here. My original had a big hole cut in it and my solution to hold fridge plug and usb ports did not workout.
He's been working on my order and I got sidetracked with the Icon cap fitment. Too many small projects. :)
Hopefully he can respond.
👍I was disappointed but not surprised...at my fix.
So what are people putting into @BenCC's excellent mounts for charging?
Anyone found a USB-C PD vs. Blue Sea's USB chargers?
I’m adding an aftermarket sub to my LX and just started thinking…man, it sure would be nice if that space where the Levinson sub (you know, the one that does nothing) could be repurposed into useful real estate. @BenCC have you thought of printing a flip up/down cover for the grill/cup holder I just removed?
This is what my cousin helped me come up with last year for that spot. Only down side is that I need to unscrew the new cover to access it, but not a huge problem.
Anyone know if the 3rd row upper ac vents have been created? Mine are all broken and would love to be able to reprint a replacement or purchase without spending an arm and leg for it.
Sorry @RootMeanSqr - for some reason the link didn't post. Can you post again or edit your last post? Thanks.
Is there a post in here about Ben's process to make the parts smooth and prep them for paint? I think it's bondo + sanding but wanted to double check and see if I missed a post with a write up.
Thanks all.
Tested the three-switch mount. The rectangular hole is a few millimeters short for three switches. Too bad it cannot be fully recessed.
This is one of the configurations. Planned to have
1. 1V2H (V: Vertical, H: Horozonral)
2. 3V
3. 2V (recessed)
Let me know what you think.
Was the 2V (recessed) ever fabricated?
I'd buy at least one of these. I busted mine, and it looks like the roof liner has to come out to fix it. I'd rather not do that. A drop-in replacement would be great. I'd even accept one that doesn't pivot, and can withstand a minor bump (especially if I install a storage shelf).
Thanks all.
I think most people leave the resin as-is since its pretty close in color and his machine does a pretty good job of smoothing. But if youre wanting a very smooth finish, bondo is a great solution.
