Anyone seen a Full-covering FJ40 Bikini Top?? (1 Viewer)
Dirt Road Tops makes or made (don't see it on the website) a bimini top of excellent fit and quality.
Works great with oem bows.
Yes... Bimini tops
x2. OEM bows and a Bimini top. Here's my old setup.
Hi, found this pic of a Jeep with a soft top which covers the whole vehicle, but not the sides.
Here's a pic https://www.4wd.com/sku/Smittybilt/400x400/93615-01.jpg
Anyone seen this for FJ40? I have a bikini top from bestop, but it makes the back seats basically useless.
Thanks!
What the f*** is up with all those websites that block foreign IPs !??
I can understand they don't want to sell oversea but completely blocking foreign IPs is rude !
Still not as worst as websites like Smitty Bilt that block at the Firewall...
I can buy their product on Amazon or some other merchants but I can't see the product sheet on their website !
In these last weeks I found a lot of websites linked to 4wd gear are blocking foreign IPs, what is going on ?
Never experienced that before this year.
Thank you! I haven't seen this page on SOR before. Looks like it required an extra roll bar...?
Yes family cage
Anything you do you would need to get an extra bar in the back to hold it up... Or as u said it would make the rear seats useless
I had this one also from sor ... loved it
Neat! Unfortunately it fits 9/73 rollbars and newer. Mine is 5/73. :doh:
If aftermarket or somebody used an oem rollbar in your pre oem rollbar truck.... then you need to check the distance to see if it will work
From sor: “42-3/4 inch measurement from front outer top of windshield frame to center of roll bar”
Can you still buy OEM bows, or does anybody make repops?
Real Steel sells a full kit for around $1100.
I wish there was a simple bow kit just for a bimini that maybe connected to the roll bars
I have no desire for a full soft top, but would love a bimini.
Same here.
Several people bent their own oem bows ... back when there were no other options
You could bend your own rear bow ... or ... buy just the rear now from real steel?
Make a spreader bar to hold it taught
Just an idea
Would love to have the family top, without buying a family cage for $$$ Seems there's got to be a relatively low tech way to make one work.
(KISS: Keep it simple Stupid) Also, keep the hard top option if you chose to.
I found a couple of great examples from some Mud members hoping to hear back from them.
@ArizonaFJ has the Olive and @ErikinSC has the Dune Beige
This worked for my need. Bolts onto the factory side loop. Fits inside the facotry hard top. An alternative would be to use a 2nd main loop, and straight tubing between them. Should be quick and simple, and cost less than a cu$tom bar like I have.
