Builds AK HJ-75 (3 Viewers)
Using grease didn’t work
More bread. I used a marble rye, very delicious, Impressive how much can fit in there. Put a socket on an extension backwards and pushed as much in until it you could use a dowel. I just couldn’t find a proper fit.
Ben had an issue with his a while back, not sure if he fixed or replaced, but the discussion starts here:
And this came up too:
What the heck did Toyota name it in the parts catalog?
Looks like it is 83180-60040 Detector Assembly, Revolution.
Thanks for that.
Same for my BJ74.
Looks like FJ60 and 62s used the same part.
If you don't want to pay the premium for the Aus one, you should be able to find a used one I'd think.
Mine broke as well. I was able to cobble it together with some epoxy. No idea how long it will last but for now it’s working.
I've seen replies that say you can dig into the top with a soldering iron enough to get enough wire to solder the wires together again. Then fill with silicone or something stronger to stabilize that area.
That’s what I did. It’s not pretty but it works.
I had to use a razor and pick to clear it out.
Would be worth it to have a spare.
