FB market place. Lots of searching. They are out there. This one is a 2021. Came with regen warranty and full warranty till 4000 hours. It has 2500 hours now.
What I learned while researching. Kubota or Takeuchi. Get more than you think you will need. This one is 2 spd, fully optioned, hi flo hydraulics, AC/ cabbed. Tilt up door which only Kubota or Takeuchi do. Side open doors wont open if boom is not all the way down. Planetary drives. Vertical lift. Joystick control over combo of joystick and footpedal. Indipendant hydraulics systems for drive train vs auxiliary hydraulics so that motion is not sacrificed under load. Bucket breakout force, traction force, and tipping load are what I looked at for my needs. If you are doing a ton of dirt moving, radial lift I hear is better. Vertical is better for truck loading and pretty good for dirt. One I got is 95hp which strikes this balance best. Kubota is easier maintenance access. Kubota has the best and roomiest cab. Joystick response and travel smoothness is far better on Kubota than Takeuchi.
Test drive before you buy.
Thanks!
I have rented a 95 hp Kubota a couple of times, and a 75 hp one once also. I would use one mostly for pushing over and moving mountain cedar trees, though moving dirt and rocks would be a close second.
@ceylonfj40nut awesome purchase! I am in the market right now for a skid steer and have settled on a tracked Kubota, for many of the reasons you have stated, but am torn between the SVL 75 or SVL 95/97. Like workshops and other projects, I keep hearing to go bigger than you think. For me, there is a bit of a price difference, especially if new. Plus, the SVL 97 is 13k # in weight, so I would also be looking at a domestic HD diesel truck and large trailer to transport it around. Primary purposes would be moving dirt and large rocks for initial landscaping on a 5 acre property, along with snow removal and access road maintenance. Secondary use would be trailering it about 30 mile to a timber property to harvest and mill 30-40"+ diameter trees for fence posts/railing and other construction related usages.
I also would do a Kubota mini ex for digging/trenching, but would likely sell than in 2-3 years once all of those projects are complete. The skid steer would stay. Curious to see why you went with the 95 over the 75. Same with @1911 since you were able to test out both.
