Registry 8x Series V8 Swaps (20 Viewers)
Ill try it out this weekend. I assume that red wire also goes to your GM ecm.
@TLC94LS Sorry, I don't check this thread often. No, the red wire is a +12V Ignition feed with an inline 470 ohm resistor. To sum up the extent of the alternator one wire circuit. I supplied a +12V Ignition with a red wire that has the 470 inline resistor, the same red wire is spliced about a foot from the alternator and connected (with another splice) to the yellow with blue strip wire near EA1, which I mentioned a few posts back. Hopefully that helps.
Makes sense. I just left the one wore connected to the ECM. I may move on from this for now. I don’t feel like digging out an ign hot and messing with it. Thanks for the input!
Anyone try louvres, did they seem to help?
I do have vents on my hood, and hood rises. I never did a before and after for temps though. I don't think it significantly lowers temps. Mechanical fan clutch and blade may be the way to go.
Darren those are Ancient Aliens hieroglyphics on your hood
Thanks for the replies. Based on what you did I think this should work on my 94. All the wires were on the old alternator. Use the blue/black 12v IGN, add in the 470 ohm resistor, then splice the blue and yellow wires together. My only question is if the yellow wire needs to be spliced before or after the resistor on the 12v ign source.
This didn’t work updated below.
My limited knowledge would say that is not a splice where as (I12) would be.
Here is a video showing what I did real quick. From what I read on the dirty dingo site. I believe I will get the most use out of my alternator. By hooking up the sense wire, the alternator can sense the load for charge and put out more amps. It is set to a default setting if just left alone. I figure since I use electric fans and adding lights, winches etc. I want it to be able to ramp up. Read the dirty dingo info for yourself, which has links to GM data.
For the guys who have “finished”. I had Torfab connect my AC a couple months back. Not sure if I had a leak or if they didn’t fully charge.
Does anyone have details on how much Freon we should be putting in? 6.0 l96 with. 6l90. One pick is before AC is kicked on. Both sides around 48-52psi. Once it’s on…this feels like we are low on Freon.
Also pressure will
Assume you mean the blue side. The second pic is it running with AC on.
Those pressures are almost equal not supposed to be like that . I can tell you I start off with 2 of the small cans you can buy at local hardware store. Is the compressor engaging the high side red should be way higher in pressure than that . There are some variables to this. I do my own ac stuff and home hvac.
Oh and not hardware store auto parts store.
Thanks. Oddly enough in WA you can’t buy the cans. But we have no emissions requirements. So go figure. The pics are backwards. The 1st pic was with the AC running. I did check the clutch. I watched prob 10 or so YT videos to diagnose before coming here. I assume the system is low and it may have a leak. I have a buddy that is a mechanic who has offered to let me use their machine to evac the system and test it. So I guess that’s the next step.
If you search you’ll find that easy, CEL is little bit more tricky, Gm puts out 12v I believe and Toyota needs a ground or the other way. Look at my YouTube videos. I show all of that.
