Registry 8x Series V8 Swaps (24 Viewers)
Guys, he has a Gen 5.
Couple pieces of advice. 100% absolutely skip that style motor mount. They are OK for about a year and then you will blow the bushings out. Not only from my experience but others as well. Think about the actual surface area between the bolt and bushing, contact, it's the size of a pencil. Those are for race/drift cars that don't have lot of chassis flex and have high upkeep.
If you choose to ignore this advice and keep going with that style, those short tabs will rip off the frame eventually. Whatever you do needs to be plated and use the entire height of the frame rail.
Theoretically you could buy Gen 3/4 to Gen 5 adapter plates and use my kit but you would probably be better off just fabbing brackets to use the Gen 5 truck mount designed for your block.
@ceylonfj40nut is in the middle of a 60/80/LS and will probably be able to give you measurement soon but he is using Gen 3/4 so keep that in mind. I would still follow the others advice and wait till you have the body.
Thank you for that advice. Seems to make sense, and the thought had crossed my mind regarding the strength.
I do have the original chevy mounts, but not the frame tabs.
Maybe I'll reboot on that.
What have you guys with the LS swaps been doing for gas tanks? The LS just uses a regular pump, right?
I'm planning on using the factory pwm chevy pump, so that likely means modifying a tank to accommodate it, or custom tank fabrication.
On other forms, I've seen lots of talk of using a F150 tank in the original spare tire location. But these have been trucks and 4runners.
I found a thread here that used an old camero tank, but not much else.
Been doing some pricing on an LS Swap for the ol girl. Anyone have any recommendations for places in TX? I just talked to a guy from Texas LS Solutions in Dallas. Found their shop on FB Marketplace
@DangerNoodle I would recommend proffitts in Colorado. Don't be afraid to travel for a project like that. It's a big investment.
Leave the tank alone. The stock pump is enough unless you’re modding the engine for significantly more HP. A simple upgraded pump in the stock location is plenty adequate.
This^^^
A Walbro 255lph or Supra turbo pump are pretty much drop in, and plenty of pump if you are going north of 400hp.
Triple Locked action! All
Working after replace the lock switches! Rebuild transfer case motor as well! Huge relief.
Well, 2 problems. Maybe 3.
This isn't an LS
The chevy LT system uses a pulse width modified (pwm) signal to drive the pump. Variable speed, basically. No return fuel line.
And 2nd... i have 2 stock tanks. Both are absolute junk.
3rd, the center driveshaft location now might have interfered with the stock tank anyway.
What the hell - 4. Would like increased capacity. 😜
So that big open space in the rear of the frame is just too tempting.
This isn't an LS
I’m not sure older LT trucks use that pulse system. Older don’t. Mine has a return on the fuel rail so I was able to keep the Toyota system almost stock. I think it depends on your year. I’m running the stock. Toyota system. Not sure what you mean by center drive shaft? I can take some pictures if you need any help.
I just need the other half of the mounting flange.
It's a 2020
This isn't an LS
What rear axle do you have.. stock?
What Cold Air Intake do y’all suggest I use to be placed in same area where the original air filter sits on the 92 80 series? Connected to the LS 5.3 , air raid, K&N, rough County?
Yes. But I've got a spare pair too if we break one. 🤞 😜
9.5" Full floater 4.11.
Not sure yet about gearing. Maybe the 4.11 will work. Will be running 35's. The 6l90 1st ratio is 4.03 and sixth is 0.67.
The atlas t case has 3:1 low range.
The full floater is a major reason we went with the 80 series.
this is what i did
works perfect ceap and easy to do
