OEM is OEMEverything is OEM. The steering gearbox is an OEM remanufactured one from Advance Steering in Indio, California. Starting to think if the potential bent column/shaft is also the problem. I haven’t done my due diligence on some of the things @baldilocks described above so need to do quite a bit of homework.
If the column is in fact bent, is the recommendation to replace the upper shaft and the intermediary shaft? I love Ih8mud but also hate how much info there is on all these forums. If the gearbox is bad, should I replace with the 105 shaft one? Etc…. Too many potential causes to my issues.
Remanufactured from Advance steering is not OEM
I doubt a bent steering shaft is your issue, I would bet it's a bad steering box.
