It does, CDAN has one.
Things I've learned:
The glove box light will only work if the headlights or park lights are on.
Thanks for collecting all this info Joey!
24mm for front and read differential fluid.the bleeder screw on the LSPV
That's what I used when my "OEM" connecter went south. In the rear, you can buy a plug and play 4 pin that plugs right into the harness. Don't for the life of my understand why they hack the tail lights at the import docks.Did all the 80s have that?
They are either 10 or 12mm square, not 13.Er, I'll need to check this because that doesn't sound right. Besides, weren't inspection plugs square to use an adjustable wrench?
That last part, Sir, is probably the largest piece ofDid you know the probability of f*€king something up on your truck approaches 1 on a matrix with how many units of alcohol you've consumed?
Thus, it's probably best to hold off on step #6 until after the repair has been completed.
Land Cruiser advice I've heard.
Did you know that if you can't get your truck to start and need to move the shifter into neutral you can remove that little square plastic piece in the front driver side area near the shifter - push down the button and then be able to move the shifter?
Not sure when the stopped but my 92 80 has a "Shift Lock Release" button in front of the shifter lever. No removing of a piece of plastic necessary.![]()
Stopped? You mean started. My 97 has the plastic plug![]()
