Did you know there is a plastic pocket available that fits over the driver's side rear wheelwell? Used on JDM trucks to carry the warning triangle kit.
anybody have info whether it fits an LX ?
Did you know...I would have been doing these near real time but today was a busy day. Here are two more that were referenced in the beginning of the thread. The first post was changed to reflect the changes. Thanks to @canman and @2MinutesTurkish for the suggestions.
View attachment 1052683 View attachment 1052684
the bleeder screw on the LSPV
where?Did you know your LC has at least 4 built-in bottle openers.
Door latches.where?
Did you know...
You need a spelling editor!
And two more at the conviently opend tail gateDoor latches.![]()
Did you know there is already a trailer wiring harness? no need to hack into the brake circuit. Just untuck it from the rear pass-side frame
Wait, wait, I got a better one.
Did you know that some trucks came with all-red hazard switches and apparently nobody in the wholeworld knows what the actual part number for those
things is? Even searching the printed and moulded numbers on the switches themselves- even on Japanese auto parts sites and at Japanese Toyota dealer parts counters- gets you nothing! What the
is up with that!?!
They do exist, we've seen them, we have pictures and actual switches. So where do they come from?
NOBODY KNOWS!!
(Now THAT is some interesting information! Like they just appeared out ofnowhere, or came out of an alien spaceship in Area 51 or something...)
I do apologize for my profane frustration with this issue but I even go to Japan every few years and the last time I tried to get one over there they couldn't find a part number for them either! OR a switch! In the same place they built thethings! How could they not know? But they don't.
24mm for diffdrain plugs and trannydrain, (and fill) these should be replaced with internal hex (see Beno).
15mm for aftermarket shock tops like Koni (must be a bimmer thing).
13mm if you have aftermarket battery cables that may have come from NAPA.
15mm if your oil drain plug is aftermarket (ham fisted nut turners be damned).
22mm Front Panhard/Control arm bolts
24mm bolts on the rear control arms
54mm socket for the hubs
But in all reality, you should only need the stock stools from the bag to do most things on the road...
Did you know you can straighten a tie rod that is bent 3 different ways by hanging a steel rim off your winch bumper. Running the winch cable through the center of the rim and use the winch to pull it back straight? Use vice grips wedged against the rim to keep the rod from turning, don't try to hold it with your hands. May also work with links but I have not tried that yet!
edit, with the tie rod off that is.
If memory serves, the inspection/fill plug for the steering knuckle is a 13mm box end. . .
Did all the 80s have that?
