80 Series Aftermarket Gauge Choices & Mounting Options (2 Viewers)
This option will be hitting the market very soon as well. The big hole in top will have replaceable faceplates you can customize or we will have a bunch of options from the get go (gauges, switches, etc).
This is (maybe) obviously the shifter console (to go with our soon to be released center console), so putting gauges down there is more of a "once it's tuned" thing and a "hmmmm, something seems fishy" thing, than an "I have to keep my eyes on this gauge" kind of thing. Which is what a properly setup system should be anyway.
This piece will fit both the 91-94 and 95-97 dashes, so all good there.
Is this on the market? If so how would look at it and on order? Thanks
Yeah, that just looks like quality right there.
I gotta admit I like this far better than the tweaker-bait of the A-pillar unit (despite having tried to make it work).
While guage placement means you glance down, not having a big pod advertising your 80 from 30’ in a parking lot (assumes you aren’t on tires, lift, armor) - helps.
A person has to get close to know you’re probably running anything from a SC/turbo to a LS3/LSA under that hood.
Better pry the lizard off the grille then, too...
was searching a way to plug in a sensor to monitor Trans temp and knew I saw a thread somewhere long time ago. Anyway, for those that also want to add an extra sensor here's the info needed.
I remember this thread. There's another and better option out. I'll make it quick, stay away from placing the sender in the pan. It's not an accurate representation of what's going on with the trans fluid temperature. Get a new union for the line out of the transmission, drill and tap it for the sending unit.
Edit: Here's one of them.
link to the thread would be awesome if you have more info on this. Thanks
Search the diesel section. A temp sender in the pan is near useless. One can replace the OEM sender in the cooler union or Wholesale Automatics sells a pre-drilled union that accommodates both or drill and tap your own union at the elbow to accommodate both.
Question....
I want to be able to send Oil pressure sender data using an aftermarket VDO 360 025 Gauge Pressure Sender (instead of the factory sender supplied by Joey). I want the data sent to both the PLX gauge and also still have the idiot light on the dash cluster. The factory wiring harness for that sensor is simple 2 wires (one for pressure and one for the warning light (WK). Does anyone happen to know if I can just hook all 4 (2 per terminal) wires to the VDO oil pressure sender? Or will I need to install the factory oem and the VDO sender so the lines are separated? I'm trying to reduce the amount of T's needed. Less places to look for oil leaks and also want to minimize it looking stupid running 2 Wits End PeacePipe Ts together.
Question....
I ran my aftermarket sensors (temp & pressure) off a sandwich plate adapter that was threaded for 2 sensors. It fits flush between the engine block & oil filter.
Yeah I was thinking sandwich plate if I'm unable to only use just the aftermarket oil sender. Ideally I want to use the single aftermarket oil sensor to send signals to both the PLX and oem in dash idiot light. I still want the dash light just in case if I don't catch it on the gauge. I like the idea of backups!
Im running both OEM & aftermarket displays.
my aftermarket has an illuminated & audible warning indicators. I can’t imagine you could miss all of those warnings.
ok so stock sender in block with oem wiring and then sandwich plate for aftermarket sensors.
Do you know if I just ran that single aftermarket oil sender in the Wits End Turbo Tee if I can tap all 4 wires into the same sender? I'm wondering if that would cause a low voltage or something and weaken the signal.
sorry, that Question is way above my pay grade.
hopefully someone with more knowledge will chime in.
I ended up going with the AEM gauges, I liked that they had a highly rated two in one boost/ AFR gauge that runs on a well reviewed bosch wideband sensor that doesn't require open air calibration. It sounds like a lot of wideband sensors out there can be very unreliable and don't last long, or you have to take them out and recalibrate them frequently.
I decided on boost, afr, water temp and a water/meth flow gauge. I already have oil pressure on the cluster and I trust it, especially with a new pressure sending unit that Joey included in the kit!
I went back and forth on where to mount the water temp sensor, I wasn't a big fan of cutting the hose and putting in one of those adapters. After looking around a bit I came across a spot on the upper hose tube that bolts to the block. It looked like it was begging to be drilled and tapped, so that will be my project in the morning. I'll be sure to post an after pic of the install. I attached a few pics showing the location, looks like a perfect spot for a temp sensor. It's a little painful pulling the tube, I removed the alternator, then the alt. mount bracket to access the two bolts that hold it to the head. It would be a great time to replace the coolant tube and gasket if you have heavy corrosion. I had replaced it roughly 5k miles prior during HG job, it was in bad shape.
I'll be sure to post a follow up once all the gauges/sensors are installed.
This looks great. Do you have an photos of the hardware you used to mount the autometer plate?
I'll make sure to get some pics posted as soon as I can. The Turbo/gauge install turned out great, couldn't be happier. I had to hit pause on the project for awhile, outta town working some serious OT. Looking forward to getting back to it soon!
I totally forgot to post up my gauges after my install. Take a look at it here:
