Builds 73 FJ40 Refresh
I found a couple more small glimpses of the tube hanging down during rocker repair. Thank you @diesellibrarian
Does anyone know what this part looks like in real life? 71141-90322
From pictures I have been able to find it looks like a washer, but the parts diagram doesn't.
@Engineer8000
Going by what’s on my ‘75…it seems to be a 1” size washer about 3/32 thick….this is only a guess as I did not remove it but…this also could be something someone added somewhere in the last 50 years?
Much respect on this work
Ready for test fit. I ordered this 6 way sealed connector for the rear chassis harness connection. I need a few other 6.3mm bodies to replace a few originals that are kind of rough. I added a charge light relay that will turn on the brake light if the alternator dies. I wrapped the main power wires from the ignition switch to the fuse box separately so if I have a melt down, it will not damage the rest of the harness.
