Builds 2F + (3F-E) = 2FETI Into My FJ40 (5 Viewers)
Woo hoo, you must be pumped to be so close. Pity about the wait for the surge tank. :(
Thermo fan and Craig David water pump now come on with the ignition. Just have to zip tie up a few cables to make it neat.
The ECU is now calibrated for the TPS
Boost is calibrated too and working now though I can only blow 1.5 PSI on the gauge :D
So just the fuel and power steering hoses to hook up :steer:
LAP TOP AND FJ40, SUREAL
Matt - OK - I think your ready for he next FAST AND FURIOUS!!
Ok Sony DVD Handycam on charge :rolleyes:
Water pump bypass hose ready to be fitted tomorrow along with all the power steering hoses/cooler, now the steering box is back on after been full rebuilt.
Have to remount the washer bottle, radiator over flow and both horns and reconnect the head lights.
Fingers crossed Wednesday sees the surge tank arrive, Thursday at the latest. If it does transport to the Dyno will be booked for Friday and Dyno on Monday, if not it will be the week after at the very latest as Monday is my free day
Spent most of the weekend going over the start up program that Joel has written, some of it I understand some I have yet to learn. Some I have altered and emailed back to Joel. If you want to have a look you can down load the Wolf V500 software for free here. Download Link and I can email the set up so far.
I'm going to beat you! Big gay is going in today.:D
Turbo timers are great as long as you are not upside down at comp, I have seen a couple of engines destroy themselves after the ignition has been turned off after a roll only for the turbo timer to keep it running, OOOOPPPPPS and most you can't override once the turbo timer has taken over.
We will not be running a turbo timer :D
The turbo timer on my RX 7 is actually manually operated. you hit a well placed button on shutoff and it keeps it running. you can turn it off normally. might be an idea if you decide to go with one in the future
I had a look at the wiring diagram and set up, it's not too hard to do. The ECU has a timer where it takes it's 12v from an alternative to the ignition. All I need to do is make that so I can switch it on and off.
Bypass hose connected water filled and pressure tested.
NO leaks :bounce:
Power steering hoses and cooler fitted and filled.
Oil hmmmmmm some one for got about been able to get the dip stick out to check oil level :whoops: Just able to get away with it as long as I take (one bolt) the ignitor off :D
Oil filled
Washer bottle and expansion bottle re mounted all connected and working.
Just fuel left to do :steer:
ARE WE THERE YET:hillbilly:
Fuel pump mounted along with the pressure regulator Surge tank comes in lunch time tomorrow. Fuel lines to connect once in place.
I's dotted T's crossed off to the DYNO on FRIDAY :steer: Ready for start up MONDAY :clap:
One final question for mudship.
The PCV valve on my 2F-ETI connects to the same location as would the 3FE, feeding into the plenum. My concern now is the PCV valve was expected originally to run in a Vacume enviroment. It will now also be posative pressure as well as vacume.
Is the PCV valve one way only and therfor not effected by boost or should I run the PCV valve no to a catch can? i don't want to be boosting the crank case :eek:
The PCV is only one way. It will close under boost.
Fuel lines made up.
All connected
Surge tank mounted.
Just need to make a bracket to suit the fuel pressure regulator but still connected up.
DYNO time ships out tomorrow Dyno Tuesday and Wednesday :steer:
The bonnet is closed :bounce: hmmmmm sleeper.
Nice work. I'm looking forward to the dyno run.
Are you concerned about the stainless hose rubbing on stuff under the hood? I heard it wears-down everything that it touches.
It is a concern but a few choice clamps and zip ties once I have time will suffice.
Things only rub if they move.
I would like to thank all those involved with this build.
1sT up Pappy I hold you totally responsible for showing me your 2FE and all the expence it has caused please deposite funds via paypal to set this right. Your shamen is acceptable :D
Colin and his staff at TDC for their oustanding work on the engine, the time and effort that went into the detail is second to none :clap:
Chris and Danial at New Car Servises as always my mechanic’s and top blokes for letting me yet again clutter up their work shop :clap:
Carlos, Awill4x4 and DaveJB for their part in the intercooler 1st class workmanship all the way :clap:
Melbourne Performance Center for the turbo manifold and intecooler pipe work along with the exhauste, work of art boys :clap:
My sponsors OZZIEWEBHOASTING for all your web hosting needs :clap:
And of course all you fellow mudders who have followed and posted in this thread :beer:
THANK YOU
PS
Isabell (My daughter who gets her licence in 12 months) no you can not borrow the truck it’s not a boy magnet :flipoff2:
HEY, keep me outta this. :grinpimp:
Seriously, I'm really interested to see how it dynos. Good luck! Oh, and the Shaman has been boxed up and is on the way to OZ. Treat him well. :cheers:
Well it's 5:35am here in Oz good job I work nights I doubt I would have slept :D
30min drive from here when I finish to the Dyno where my 40 was trailered too last Friday. Booked for an 8 O'clock start 5-6 hours expected dyno time, working tonight too :eek:
RED BULL DAY :hillbilly:
Don't forget the video camera. :grinpimp:
