Like John hinnesyBeware of these guys, they royally screwed my buddy and didn't stand behind their work, or lack thereof, at all.
Did someone tell you no landcruisers would ever have problems?This is just unfortunate. It seems I was oversold on reliability, dependability and quality of LC 200.
Of that magnitude, yes.Did someone tell you no landcruisers would ever have problems?
Don’t listen to anything else that person says.Of that magnitude, yes.
A while back Lexus had a recall for defective valve springs. At the time our LS (also a UR engine) was included but our LX was not. Not sure if this maybe affected 200's at some point?
Good to know- I think I read something about that too. Thank you!
Would a QC X-ray have not seen the inclusion?Toyota has also safety recalled 4 cylinder Tacomas and the FRS/GT 86 for valve springs. The LS460 and various other Lexus vehicles included under the old recall had inclusions in the material that were causing early failure. This is likely the same issue... is the spring wire material clean enough?
Quick read....
High Performance Spring Failure: A Case Study of a Valve Spring - IST
High Performance Spring Failure: A Case Study of a Valve Spring Within all industries, certain components are known for their precise manufacture and exceptional performance. Within the spring industry, valve springs are considered some of the top performers. These springs are typically...www.ist.org.uk
Have you spoken to anyone above the service manager? I think some calm conversations with people higher up in the chain of command could be fruitful. There is nothing a user can do to an unmodified land cruiser that would cause that. And if you had a Kia or Hyundai this would be covered under warranty.
I’ll try to speak to someone higher up again..... but when I asked they wouldn’t transfer or give me anyone’s info. I found a way to dispute a claim , so am going to try that too with Corporate. Thanks!Have you spoken to anyone above the service manager? I think some calm conversations with people higher up in the chain of command could be fruitful. There is nothing a user can do to an unmodified land cruiser that would cause that. And if you had a Kia or Hyundai this would be covered under warranty.
