Transmission and Transfer Case Vent Routing
Stock, the transfer case and transmission vents hook into a bracket that is on the dipstick tube. They do not enter the dipstick, just vent to atmosphere behind the little bracket shown below. The only opening is on the bottom of the bracket, so, mostly keeps dust and water from getting into the vents. There is no dipstick on the 8HP75, you fill it according to a fill plug on the side of the transmission, much like a differential.
I replaced the vent lines on the transfer case, as they were old, dried out, and cracked. I then ran a vent up the drivers side of the transmission and used the M8 studs on my transfer case shifter plate to hold two of the stock vent clips. I reused one and bought a second. Part numbers for these can be one of two parts: 90949-01968 or 90949-01684. One is exactly like the stock part, longer, and the other is a bit shorter. Either would have worked in my install.
For the transmission I found a Dorman part at Oreilly that is a right angle rubber part that fit the vent pretty well. I adapted this with a male/male barb fitting to the stock size vent line and ran that together with the transfer case vent using the stock style clips up into the engine bay where I used two Toyota differential vents to vent the two independently. The Toyota differential vents that I used are P/N 90930-03097, two per. The clips that hold the vent lines together are P/N 90464-00535.
Dorman right angle rubber part is Dorman P/N 47038. I used the 7/32 vacuum tubing shown below. Found both at O'Reilly.
The incorrect barbed fitting is shown in the picture below, that is a reducer and the wrong part. Correct part shown above.
