Had a call with a TurboLamik Tech this morning to do the initial setup. It was an interesting experience.
First of all, the wrong software was installed on the TurboLamik. I had software for the 8HP70, not the 8HP75. Some miscommunication happened when I purchased the TurboLamik. If you go this route, make extra sure you are specific about which transmission you are swapping in and also double check. I had written it in an email, not sure what happened. No harm done, as I had not driven it. The tech updated the TCU and started the set up.
They remote login to your laptop and use TunerPro software to set up the transmission. I had the J80 up on jack stands so it could be run through the gears with the wheels turning. At one point he wanted me to have it at 2k RPM and run through all of the gears. Idle is one thing, but 2k RPM, in gear, wheels rotating?
I almost did not do it, asked him about being on jack stands. He said that he has done this with customers on jack stands many times without any problems. I asked him about 37" tires, and he said yes, so, took the risk, and it turned out just fine, But, 2k RPM in 8th gear is like 60 MPH equivalent. If it had fallen off, I would have plowed into the house.
So, in hindsight, maybe that was more risk than I should have taken and the rig would need to be on a lift or a dyno to do that. Or, at least not facing the back wall of the garage. Completion bias probably came into play. I want this finished and took a risk that I would not normally take.
Something to think about for others if you get to this point. If I had known about this in advance, I may have arranged to get it on a lift or a dyno.
Also, the neighbors commented on the racing engine at 6:30 in the morning. I did feed back to the tech that the US dealer for TurboLamik needs to get up to speed on these setups, as the time difference is a bit of a pain.
But, no accidents, no issues. Got the initial shift map set and I took it for a test drive. I only went a short distance, stopped to look for leaks, and guess what I found? Leaks on the cooler lines. The stock clamps may not be up to the task for the line pressure that the 8HP is running. So, back to the garage to let it cool down and I am going to replace them with high pressure fuel line clamps.
Then I need to get the fluid level set. There is a very detailed procedure from ZF for fluid level setting that includes a flow chart. Link below to that procedure.
Top level summary is:
With the engine off, fill the pan until it comes out the fill hole (took 4 liters on mine, with the DomiWorks pan).
Start the engine and continue to fill until the fluid comes out the fill hole again (9.2 liters for mine, with my cooler setup).
Drive the car until the "valve opens T < 75C" then follow the flow chart.
ZF8HP Transmission Fluid Fill Procedure
Once I get the fluid level finalized, I need to put it into adaptation mode where it will adapt the shifts. This is done driving in manual shift mode and is recommended that you shift at 2k RPM. There are four upshifts that are used to adapt the shift parameters for clutches A, C, D, and E. the B clutch is adapted on the 6-5 downshift. All sounds technical, but all you need to do is activate adaptation mode in the software and then drive it in manual shift mode, shifting up at 2k RPM for each shift. it shows a little "A" on the screen when adaptation parameters are met and you are good to shift. Just shift at 2k once the A shows up on the screen. They want this done 20 times, through the gears shifts that set on upshifts.
Adaptation in TurboLamik Manual
I will post up a video of it driving once I get the leaks fixed, fluid level set, and the adaptations done.
Nice to actually drive it this morning. First gear is seriously low at 4.7:1. The 1:2 shift happens really fast, as the RPM's just ramp. Shifting is a bit unrefined at this point and will see how the adaptations smooth that out.
Thanks,
Mike
I can imagine how alert you were when the truck was doing 60mph on jack stands
Thanks for sharing all this with us — seriously incredible
