Finally scored what seems a good running FZ with all the fixings, pulled for a transplant. Cost a little less than my Cruiser did in 2015
, but hoping its condition and low-ish miles (approx 170k) will slash rebuild/refresh costs
. The engine is now on a pallet; I’ll get it on a stand, once I get a crane and a stand (it’s been decades and several moves since I did this kind of thing). I would prefer not to tear it completely apart, hot tank, machine etc., unless NOT doing so would just be dumb(?). I'm thinking that *if* things look good enough, I can do some preventive maintenance/replacement, drop it in as-is and turn the clock back 70k miles minimum. And then take my sweet time (and spread out the expense of) rebuilding the current engine (240k), Joey OCD-style.
QUESTION ONE:
What steps can I take to gauge the state of the ‘new’ engine (and accessories) and see if everything’s ready-to-go? What can I look at, measure, test, etc.? If I can do this without machine shop costs, great. Unless that's dumb. If that *is* dumb, what if anything should I have a machine shop look at instead? (If I can buy the tool for the cost of them measuring it, I'm inclined to buy the tool. Value of experienced eyes on the parts beyond that, though: priceless. Maybe photos on Mud will do for some things?)
QUESTION TWO:
Any downside to running the same pistons/rods/pins if the bore is in spec? Should rings be changed and bearings checked? Does replacing bearings mean machining the crank and significant additional costs? If this is the difference between 100k more miles and 200-300k before rebuild, fine. If not and things look good, I can just leave pistons/rods assembled and put the money elsewhere.
QUESTION THREE:
I'm assuming that if things look good and crosshatching visible, and PM/replacement done, the engine will make 300k or better even with untouched pistons/bearings. I'm also assuming that the head (if reused as-is, and in decent shape now) will become the weak point and require rebuild before the refreshed bottom end. Are these assumptions correct--and what's a good guess at the rebuild-required mileage for the head?
INTENDED USE: 90% DD, 10% overland; nothing extreme, no turbo, no crazy RPMs or serious crawling. S/C install (if/when I can swing that). Occasional towing. Maybe ~1200 lbs over stock sprung weight for DD; heavier when offroad.
Will post up list of intended PM/refresh parts/work for comment/additions.
Would like to do this...
But my budget is closer to this...
QUESTION ONE:
QUESTION TWO:
QUESTION THREE:
