Trust me. Whatever EB is telling you is wrong. Whoever EB are.
Call up and talk to a real ****ing human being who knows what they are talking about.
Yeah. I think that is a good plan.At $400 and given they're lifters, I'll just reuse mine assuming they're in good working order. Thx, Atomic!
Have a sip of coffee, dude. I said I'd keep digging.
No.Looking over your list as I’m doing the same in the next couple of months. Isn’t the rear main included with the short block?
I’ll add it to my list then, thank you sir!
It comes in the 04111-66036 gasket kit.I’ll add it to my list then, thank you sir!
Part description | Qty | Part # | Notes |
Cylinder head | 1 | 11101-69107 | Possible to reuse, but I went new |
Block assembly | 1 | 11400-66041 | Possible to reuse, but I went new |
Head bolts | 14 | 90910-02111 | |
Head bolt washers | 14 | 90201-12222 | |
Fuel injector | 6 | 23209-74080 | You can rebuild these for less $ |
Steering gear assembly | 1 | 44110-60212 | Steering - comes with 105 shaft |
Arm pitman | 1 | 45411-60360 | Steering - need it to fit the 105 shaft |
Steering bolts | 4 | 90105-12110 | Steering |
Steering nuts | 4 | 90179-12085 | Steering |
Front engine mount | 2 | 12361-17011 | Mount |
Rear engine mount | 1 | 12371-66030 | Mount |
Rear main seal | 1 | 90311-99009 | Likely extraneous; think it comes in the engine kit |
Bolt stud | 4 | 90080-12007 | |
Nut lock | 4 | 90080-17187 | |
NUT, LOCK- FOR MANIFOLD TO HEAD | 13 | 90179-10128 | |
BOLT, STUD- FOR MANIFOLD TO HEAD | 13 | 90116-10169 | |
Valve cover gasket | 1 | 11213-66021 | Comes with the engine kit |
OEM throttle body gasket | 1 | 22271-66010 | Likely extraneous; think it comes in the engine kit |
OEM spark plug tube seals | 6 | 11193-15010 | Likely extraneous; think it comes in the engine kit |
Engine kit from 1998 | 1 | 04111-66061 | This is the 105 kit; cheaper (thx to @SNLC) |
Oil pressure sender unit | 1 | 83520-60040 | |
11434H Front near timing cover | 2 | 90253-11021 | |
11434X bottom right | 2 | 90253-13002 | |
11415A DS Middle block | 1 | 96431-23814 | |
11434C Rear top | 2 | 90253-15007 | |
11434D Rear by trans | 1 | 90250-06068 | |
11434B Rear by trans | 2 | 90250-08054 | |
Orifice cylinder | 1 | 11448-66010 | |
Cock assy, drain | 1 | 90910-09129 | |
body mount (under front seat feet) | 2 | 52203-60042 | Mount |
body mount (under front seat feet) | 2 | 52204-60042 | Mount |
body mount (under rear seat feet) | 4 | 52205-60010 | Mount |
body mount (under rear seat) | 4 | 52206-60010 | Mount |
body mount (outboard of rear springs) | 2 | 52209-60050 | Mount |
body mount (rear of frame R HDJ81) | 1 | 5224160020 | NLA for FZJ80, but HDJ81 interchange (thx to @OGBeno) |
body mount (rear of frame L HDJ81) | 1 | 5224260010 | NLA for FZJ80, but HDJ81 interchange (thx to @OGBeno) |
Transfer case actuator | 1 | 36410-60050 | There is no non-T sourced version I think |
TVV | 1 | 25820-13020 | |
ECT sensor | 1 | 89422-35010 | |
ECT sensor washer | 1 | 90430-12005 | |
ECT cut switch | 1 | 88790-60050 | |
ECT sender gauge | 1 | 83420-16040 | |
Knock sensor wire | 2 | 82219-35010 | |
Knock sensor | 2 | 89615-30050 | |
10/5/21 Camshaft | 1 | 13502-66010 | |
Camshaft 2 | 1 | 13501-66020 | |
Gasket chain tension | 1 | 13552-66010 | |
Camshaft gear | 1 | 13529-62901 | |
10/4/21 DISTRIBUTOR DRIVE GEAR | 1 | 13515-75010 | |
CAMSHAFT TIMING GEAR/SPROCKET | 1 | 13523-66020 | |
TIMING CHAIN TENSIONER | 1 | 13540-66011 | |
CHAIN SLIPPER | 1 | 13559-66011 | |
CHAIN DAMPER | 1 | 13561-66010 | |
TIMING CHAIN | 1 | 13506-66010 | |
VALVE, EXHAUST | 12 | 13715-66030 | |
VALVE, INTAKE | 12 | 13711-66030 | |
10/4/21 SPRING, COMPRESSION | 24 | 90501-38006 | |
VALVE SPRING RETAINER LOCK | 48 | 90913-03027 | |
VALVE SEATS | 24 | 13734-66020 | |
VALVE RETAINERS | 24 | 13741-66020 | |
10/4/21 OIL PUMP COVER GASKET | 1 | 15188-66020 | Likely extraneous; think it comes in the engine kit |
OIL PUMP ROTOR | 1 | 15102-66020 | |
OIL PUMP DRIVE GEAR | 1 | 15163-66021 | |
OIL PUMP RELIEF VALVE | 1 | 15131-46040 | |
10/4/21 RELIEF VALVE SPRING | 1 | 15132-66020 | |
GASKET, RELIEF VALVE | 1 | 15134-17010 | |
10/4/21 PLUG, RELIEF VALVE | 1 | 15133-17010 | |
OIL COOLER GASKETS | 2 | 15785-66010 | |
COVER, OIL COOLER | 1 | 15701-66010 | |
10/5/21 Distributor | 1 | 19100-66020 | You can rebuild v buying new |
valve keeper | 50 | 90913-03027 | |
valve seals intake | 12 | 90913-02096 | |
valve seals exhaust | 12 | 90913-02105 | |
valve lifters | 24 | 13751-66020 | These took a while to get |
shim | 24 | 13753-66020 | A bunch of sizes |
timing cover | 1 | 11310-66020 | |
timing cover gasket | 1 | 11328-66020 | Likely extraneous; think it comes in the engine kit |
Front main seal | 1 | 90311-52022 | |
Oil cooler relief valve gasket | 2 | 15134-20010 | |
Oil cooler cover gasket | 1 | 15725-66010 | |
Bypass tube gasket | 1 | 90301-29006 | |
SPRING, OIL COOLER RELIEF VALVE | 1 | 15132-50010 | |
VALVE, OIL COOLER RELIEF | 1 | 15131-64020 | |
PLUG, OIL COOLER RELIEF VALVE X 2 | 2 | 15133-20010 | |
Oil cooler plug | 1 | 90341-20002 | |
Oil cooler assy | 1 | 15710-54030 | Pricey item; debated getting it, but did it anyways |
RING, SHAFT SNAP(FOR CAMSHAFT SUB GEAR) | 1 | 90520-41004 | |
WASHER, WAVE(FOR CAMSHAFT SUB GEAR) | 1 | 90206-42001 | |
PIN, STRAIGHT | 1 | 90250-05027 | |
SPRING, CAMSHAFT GEAR | 1 | 13579-50020 | |
BOLT | 1 | 90910-02093 | |
PIN, STRAIGHT NO.2(FOR CAMSHAFT KNOCK) | 2 | 90250-05030 | |
RING, SHAFT SNAP(FOR CAMSHAFT SUB GEAR) | 1 | 90520-47002 | |
NUT (FOR TRANSMISSION CONTROL CABLE) | 1 | 90179-08040 | |
BOLT, STUD(FOR EGR INLET) | 1 | 92122-60818 | |
BOLT | 1 | 90109-12057 | |
BOLT, FLANGE | 2 | 91511-B0816 | |
JET, OIL | 1 | 13516-66011 | |
gear, pump drive shaft | 1 | 13522-66030 | |
gear or sprocket, crankshaft timing | 1 | 13521-66020 | |
Key (for crankshaft timing gear) x2 | 2 | 95161-30516 | |
rotor, crankshaft position sensor | 1 | 19315-66010 | |
Bolt (for crankshaft pulley set) | 1 | 90119-22001 | |
WASHER SET, CRANKSHAFT THRUST | 1 | 11011-66020 | |
SEAL, OIL (FOR FRONT OIL PUMP COVER) | 1 | 90311-38020 | |
RING, O (FOR FRONT OIL PUMP BODY) | 1 | 90301-99033 | |
Rear heater pipe front section | 1 | 87209-60301 | While in there |
Rear heater pipe back section | 1 | 87209-60441 | While in there |
Clamp heater | 4 | 87124-28040 | While in there |
Clamp heater | 6 | 87124-60070 | While in there |
Bolt | 2 | 90119-08197 | While in there |
Nut | 3 | 90179-06161 | While in there |
COIL ASSY, IGNITION | 1 | 19080-66010 | Non-engine |
IGNITER ASSY | 1 | 89621-26010 | Non-engine |
Harmonic balance, pulley crankshaft | 1 | 13470-66030 | |
RING, O(FOR FUEL PRESSURE REGULATOR) | 1 | 90301-09002 | |
REGULATOR ASSY, FUEL PRESSURE | 1 | 23280-75010 | |
INSULATOR, INJECTOR VIBRATION | 12 | 23291-41010 | |
BOLT, UNION(FOR FUEL PIPE NO.2) | 6 | 90430-12026 | |
HOSE, FUEL(FOR FUEL INLET) | 1 | 90923-01396 | |
BOLT, STUD(FOR INTAKE MANIFOLD TO CYLINDER HEAD) | 2 | 90126-08008 | |
THERMOSTAT (HEAD) | 1 | 90406-17007 | |
UNION(FOR CYLINDER HEAD) | 1 | 90406-08011 |
Hope to get a chance to grab a beer with you while looking longingly at both of our refreshed 80s at a time that will surely come.Once again this is clearly a tremendous effort and you are without a doubt going to save some mudders a lot of time.
I hope to start the same job within the next year or so and I'll definitely be referring to this when that time comes.
Thanks again
This list is great. Maybe I shouldn't ask, but how much should one budget for this kind of engine rebuild?
