1FZ-FE engine refresh parts list (OEM) (10 Viewers)
Have a sip of coffee, dude. I said I'd keep digging.
It’s night time. I’m already drinking. :lol:
Here's likely the final update to the raw OEM parts list that's custom to my rebuild. You're not seeing a lot of the major accessories like pumps, radiator, hoses and filters because they were already replaced with new 3 years ago. I'm also replacing every bit of the EGR system (parts gathering dust as we speak).
As you can see from the go, there are non-engine related parts that I incrementally added as a "while in there" effort. I accrued the part numbers by just doing a bunch of search on ih8, DM'ing some other rebuild OPs (u know who u r thx) and referencing partsouq db. I'm certain to miss bits and pieces, but live & learn, enjoying the journey. :)
  • The lifters took the longest to source, even longer than the short block which came straight from Japan
  • I'm just going to let the machine shop handle the shims for obvious reasons
  • The engine harness I got maybe half a year or so ago is made in Vietnam; everything else on my list is Japan made
  • I sourced parts from four primary vendors: 1) A SoCal Toyota parts center; 2) Partsouq; 3) Boch Toyota; and 4) Amayama
    • Partsouq is definitely the most reliable and best packaged
    • Amayama is hit or miss so I avoided them except for the bigger ticket items that cost markedly less than Partsouq or weren't available via Partsouq (consistently longest to ship)
    • Boch Toyota hasn't botched an order yet, but their packaging needs work and their communication is sparse which is ironic given they're USA-based
    • Fedex charged duty tax via snail mail on the power steering gear order which might be because the thing is pushing 50lbs (maybe raised some eyebrows at the airport)
    • If anyone wants a referral to the SoCal Toyota parts guy, DM me (shipping a short block is a non-starter!)
Part descriptionQtyPart #Notes
Cylinder head111101-69107Possible to reuse, but I went new
Block assembly111400-66041Possible to reuse, but I went new
Head bolts1490910-02111
Head bolt washers1490201-12222
Fuel injector623209-74080You can rebuild these for less $
Steering gear assembly144110-60212Steering - comes with 105 shaft
Arm pitman145411-60360Steering - need it to fit the 105 shaft
Steering bolts490105-12110Steering
Steering nuts490179-12085Steering
Front engine mount212361-17011Mount
Rear engine mount112371-66030Mount
Rear main seal190311-99009Likely extraneous; think it comes in the engine kit
Bolt stud490080-12007
Nut lock490080-17187
NUT, LOCK- FOR MANIFOLD TO HEAD1390179-10128
BOLT, STUD- FOR MANIFOLD TO HEAD1390116-10169
Valve cover gasket111213-66021Comes with the engine kit
OEM throttle body gasket122271-66010Likely extraneous; think it comes in the engine kit
OEM spark plug tube seals611193-15010Likely extraneous; think it comes in the engine kit
Engine kit from 1998104111-66061This is the 105 kit; cheaper (thx to @SNLC)
Oil pressure sender unit183520-60040
11434H Front near timing cover290253-11021
11434X bottom right290253-13002
11415A DS Middle block196431-23814
11434C Rear top290253-15007
11434D Rear by trans190250-06068
11434B Rear by trans290250-08054
Orifice cylinder111448-66010
Cock assy, drain190910-09129
body mount (under front seat feet)252203-60042Mount
body mount (under front seat feet)252204-60042Mount
body mount (under rear seat feet)452205-60010Mount
body mount (under rear seat)452206-60010Mount
body mount (outboard of rear springs)252209-60050Mount
body mount (rear of frame R HDJ81)15224160020NLA for FZJ80, but HDJ81 interchange (thx to @OGBeno)
body mount (rear of frame L HDJ81)15224260010NLA for FZJ80, but HDJ81 interchange (thx to @OGBeno)
Transfer case actuator136410-60050There is no non-T sourced version I think
TVV125820-13020
ECT sensor189422-35010
ECT sensor washer190430-12005
ECT cut switch188790-60050
ECT sender gauge183420-16040
Knock sensor wire282219-35010
Knock sensor289615-30050
10/5/21 Camshaft113502-66010
Camshaft 2113501-66020
Gasket chain tension113552-66010
Camshaft gear113529-62901
10/4/21 DISTRIBUTOR DRIVE GEAR113515-75010
CAMSHAFT TIMING GEAR/SPROCKET113523-66020
TIMING CHAIN TENSIONER113540-66011
CHAIN SLIPPER113559-66011
CHAIN DAMPER113561-66010
TIMING CHAIN113506-66010
VALVE, EXHAUST1213715-66030
VALVE, INTAKE1213711-66030
10/4/21 SPRING, COMPRESSION2490501-38006
VALVE SPRING RETAINER LOCK4890913-03027
VALVE SEATS2413734-66020
VALVE RETAINERS2413741-66020
10/4/21 OIL PUMP COVER GASKET115188-66020Likely extraneous; think it comes in the engine kit
OIL PUMP ROTOR115102-66020
OIL PUMP DRIVE GEAR115163-66021
OIL PUMP RELIEF VALVE115131-46040
10/4/21 RELIEF VALVE SPRING115132-66020
GASKET, RELIEF VALVE115134-17010
10/4/21 PLUG, RELIEF VALVE115133-17010
OIL COOLER GASKETS215785-66010
COVER, OIL COOLER115701-66010
10/5/21 Distributor119100-66020You can rebuild v buying new
valve keeper5090913-03027
valve seals intake1290913-02096
valve seals exhaust1290913-02105
valve lifters2413751-66020These took a while to get
shim2413753-66020A bunch of sizes
timing cover111310-66020
timing cover gasket111328-66020Likely extraneous; think it comes in the engine kit
Front main seal190311-52022
Oil cooler relief valve gasket215134-20010
Oil cooler cover gasket115725-66010
Bypass tube gasket190301-29006
SPRING, OIL COOLER RELIEF VALVE115132-50010
VALVE, OIL COOLER RELIEF115131-64020
PLUG, OIL COOLER RELIEF VALVE X 2215133-20010
Oil cooler plug190341-20002
Oil cooler assy115710-54030Pricey item; debated getting it, but did it anyways
RING, SHAFT SNAP(FOR CAMSHAFT SUB GEAR)190520-41004
WASHER, WAVE(FOR CAMSHAFT SUB GEAR)190206-42001
PIN, STRAIGHT190250-05027
SPRING, CAMSHAFT GEAR113579-50020
BOLT190910-02093
PIN, STRAIGHT NO.2(FOR CAMSHAFT KNOCK)290250-05030
RING, SHAFT SNAP(FOR CAMSHAFT SUB GEAR)190520-47002
NUT (FOR TRANSMISSION CONTROL CABLE)190179-08040
BOLT, STUD(FOR EGR INLET)192122-60818
BOLT190109-12057
BOLT, FLANGE291511-B0816
JET, OIL113516-66011
gear, pump drive shaft113522-66030
gear or sprocket, crankshaft timing113521-66020
Key (for crankshaft timing gear) x2295161-30516
rotor, crankshaft position sensor119315-66010
Bolt (for crankshaft pulley set)190119-22001
WASHER SET, CRANKSHAFT THRUST111011-66020
SEAL, OIL (FOR FRONT OIL PUMP COVER)190311-38020
RING, O (FOR FRONT OIL PUMP BODY)190301-99033
Rear heater pipe front section187209-60301While in there
Rear heater pipe back section187209-60441While in there
Clamp heater487124-28040While in there
Clamp heater687124-60070While in there
Bolt290119-08197While in there
Nut390179-06161While in there
COIL ASSY, IGNITION119080-66010Non-engine
IGNITER ASSY189621-26010Non-engine
Harmonic balance, pulley crankshaft113470-66030
RING, O(FOR FUEL PRESSURE REGULATOR)190301-09002
REGULATOR ASSY, FUEL PRESSURE123280-75010
INSULATOR, INJECTOR VIBRATION1223291-41010
BOLT, UNION(FOR FUEL PIPE NO.2)690430-12026
HOSE, FUEL(FOR FUEL INLET)190923-01396
BOLT, STUD(FOR INTAKE MANIFOLD TO CYLINDER HEAD)290126-08008
THERMOSTAT (HEAD)190406-17007
UNION(FOR CYLINDER HEAD)190406-08011
Once again this is clearly a tremendous effort and you are without a doubt going to save some mudders a lot of time.
I hope to start the same job within the next year or so and I'll definitely be referring to this when that time comes.
Thanks again
Hope to get a chance to grab a beer with you while looking longingly at both of our refreshed 80s at a time that will surely come. :)
This list is great. Maybe I shouldn't ask, but how much should one budget for this kind of engine rebuild?
Diy - $5 to 6kish if you reuse the block. Add another couple grand if buying new. Add more if not sourcing parts from overseas. Budget $15k to $20k for turn key at a reputable shop.
My final OEM parts list above = $16.5K which includes pretty aggressive discounts from Middle East vendors + USA Toyota parts counters.
Based on my notes and parts desc, if you take out the non-engine, while-in-there parts, it’ll sit closer to $10-11K roughly.
As time passes, you will run into NLA and pricing increases so ymmv.
Fast forward 4 months short of 2 years from my original post, here's the finished product.
Food for thought, sourcing new Toyota shims might be the critical path to buttoning things up especially if you're building a new head so take this factor into account. Lifters, too. There's so little demand for them that they were in short supply here and overseas during my build.
Enjoy the process my friends and thanks for playing!
P.S. This dude is legit for sourcing T parts
Dave Stedman
Japan4x4
http://export.japan4x4.com (English)
JAPAN4x4 - http://www.japan4x4.com/ (Japanese)
Importers and Distributors
stedman@japan4x4.com
Direct Dial to Dave from the USA 510-931-6324
Fantastic Thread, thank @COYS and all contributors :flipoff2:
I'm planning an engine refresh, praying I find a supercharger somewhere on someone's shelf, and steering refresh this year.
Does anyone recall or know, I remember reading somewhere here on mud the new 80 series steering box 44110-60212 came with the 105 sector shaft already installed.
Anyone have a lead on a new or used fairly priced supercharger also?
Rock on Mud :crybaby:
