Ya know.....10K views should automatically put you on the front page
How's it going down in GA? Good looking progress on the LV! Sure would've been nice to see it in personLOL Hope you're doing well. Give me a shout sometime to talk shop!
FYI The bottom shim is to center the axle to the knuckle, and the upper sets the bearing preload. I think for the most part that people just keep track of how they came out and reuse them.
All you need to test the bearing preload is a hand held fish scale thingy. Not much to it, I did my dad's mini truck this year and the hardest part was getting the dang axle back in.![]()
SST is for determining axle center, scale is to set pre-load. My problem is I don't have an SST and I was not the person who tore down the axle so I can't guess what was before. But I have some of the new seals from Marlin coming. Just need help figuring what is my best guess is you will for center.
The closer you are to centered the longer the seal will last no matter who's seal it is.
Does that mean it's "wrong"? Not necessarily but it may not last as long.
I don't know if FoxFab has the bushings or not. I've got an extra set of hinges laying around somewhere in my cruiserpile....I'll see if any are worth using. Gimme a few days to get to it thoughMy LV stuff is packed in the corner of the garage behind all of the new FJ40 crap
LOL
Need to get this 40 outahere so I can get back to my LV!
Good luck on the axles. I didn't take mine apart...just-regreased everything and new oil. Gears were quiet and in good shape prior to painting, so I didn't mess with it.
Have you seen this thread? https://forum.ih8mud.com/showthread.php?t=141743
Alternative solutions that are more durable than the stock config.![]()
