PabloCruise
Remflex!What gasket is going to come with the header, Remflex or other?
Remflex!
I think @Dianna is going to be in the best position to answer that question. I know in this post she said it "sounds amazing" and mentioned possibly recording the sound:is this muffler designed to be loud or subtle?
I have a flow master 40 series that I thought at one time, years ago, was cool and loud but as I’ve gotten older I’m more interested in something quieter. Just curious what to expect with this system…
assuming this would be from Kieth at Dirty Deeds Ind. in Escondido? He does amazing work. great option if he produces a jig off universal oem fj40Don’t want to take away from this thread so I’ll delete or more move as desired, just let me know.
I’m having a 6” día. 22” long flow through muffler made with a hemholtz resonator attached with 90 degree madrel bend to accommodate attachment to a pipe I’ll get made locally between the header and muffler and they will also fab the tail pipe locally as well. I have a similar setup on my Tundra but this one is designed to be stock sounding while cruising and just a nice slight low rumble when you get on it. The hemholtz should take care of any drone as well.
The muffler will mount in the stock location (behind the rear axle). With tail pipe exiting on passenger side. Will look almost OEM. The setup is all 2.5” inlet and outlet, stainless and painted black in flat high temp.
This muffler would be available for others once mine is made and fitment is confirmed, company based in Escondido, CA. It won’t be cheap, but will last for a very long time and appear OEM other than color (which could easily be changed to high heat silver or polished if one desired). It could also easily be changed to 2-1/4” for use in a stock system for an OEM look replacement. The muffler by itself made to custom sizes is only $289.00 and the hemholtz is about the same, the madrel bends and custom fab work and being a one off it’s what blows up the cost for now.
I still need the header though. I will also likely install a race CAT and fab a heat shield for that or put it where the stock heat shield is after the skid plate, haven’t decided on that yet.
I’m hoping I can run my piping from the header to muffler under the skid plate. I don’t like the idea of having that piping run by the trans, transfer case and electronic speedo sensor for the Dakota gauges with no heat shield and having to modify the skid plate. I might also fab a skid plate for the section that sits below the frame so I don’t have to worry about bashing it on trails.
If there is any interest in something like this let me know separately and I can put you into contact with the maker, I don’t want to take anything away from this setup and header combo which is awesome just going a different route after the header on mine.
That’s correct Keith is Fabing this up next month for me. No jig per se, I did a mock up in cardboard and took a bunch of measurement and collaborated with Keith over the phone for over an hour. Awesome guy, great service and products.assuming this would be from Kieth at Dirty Deeds Ind. in Escondido? He does amazing work. great option if he produces a jig off universal oem fj40
I added a cat to my carb'd FJ40 to clean up the smell (I often have kids in the back) and it worked great. no smell ever.Keith recommended running CAT since I’m fuel injected and to clean up the smell. He’s saw no difference on a dyno with or without CAT on numerous applications, so in his opinion no reason not to run one unless space, money or possibly heat could be an issue.
Post #385 looks like it has the O2 bung. I think this has been asked and answered with an affirmative.Yes!!! I am ready for this. I’m in for the full enchilada!
Can these come with a pre installed o2 bung?
I see that now. Very cool.Post #385 looks like it has the O2 bung. I think this has been asked and answered with an affirmative.
Post #385 is a picture of someone else's exhaust setup. My mistake.I see that now. Very cool.
I need this !
Post #385 is my custom exhaust (NOT THE DOWNEY/MARK'S SYSTEM) I just had done for my FJ40 w/2F, Sniper, and BTB headers. I couldn't wait for Mr. Cruise's system, although would have preferred his. I will however get one for future.I see that now. Very cool.
I need this !
Very cool! I don't see any need to move your post from here, so unless I hear otherwise you ae fine to leave it here. If this idea takes off and you end up organizing some kind of group buy you can start a new thread and link to it here.Don’t want to take away from this thread so I’ll delete or more move as desired, just let me know.
