NeverGiveUpYota
Dare me.
- Thread starter
- #2,781
Wow! That is beautiful!I have the Harbor Freight Shrinker/Stretcher set. Works great. Used it to make all the aluminum trim on my teardrop.
Shop overbored. I’ve only begun adding the rings to the pistons; one is done so far. Had to stop to get ready for work at 3.Wow, good progress on everything! I see you broke out the plasti-guage to double check the math on the crank, but did you check the ring gap in the bore?
Work... always getting in the way of important stuffShop overbored. I’ve only begun adding the rings to the pistons; one is done so far. Had to stop to get ready for work at 3.
@Beerfix, this?
K, I can do that. Thanks for pointing it out. I have one set installed so far... fussy little job esp with the lube making things all tacky. I'll give the gap check a try after work today.Yes ma'am, exactly that.
This is the video I used for piston ring installation.
My ex is a teacher. And his girlfriend is one too. Two peas in a pod.Very good info but if I have to critique him as an instructor ..he really gets on my nerves when he condescendingly asks "does that make sense?" numerous times and says "k" as in "OK" like agreeing with his own instruction a few times. Another one that bakes my noodle is when instructors say "see what I'm saying?" or "right?" while instructing as if they want you to nod and say yes every time they ask.
I enjoy all aspects of the truck thus far other than electrical. It feels good to know I’ve done so much only w/ the help and guidance of all you men.Engines scare me. Rust I can handle.
Yes overbored. So the bores aren’t tapered tho?You had the block bored oversize correct? Then the gap better we'll be consistent the whole length of the bore.
