#6 is in there so does that mean they didn’t need to oversized the bore and your pistons are usable? That’d be awesome and save you a ton.
Thank you. That’s how I see it too.I don't see a reason to fill the existing keyway if you're going to use that crank. I 100% agree with machining a new one if you can make it work 180 out. Any further mucking around (welding/brazing) will not improve the crank. Even with 2 keyways the HB is supported/making contact what 90% of the way round?
It can't hurt to direct the machinist to this thread: How not to build the 2F
Now getting them to read it ...
G, I’m the assembler or will be once the machine shop is done w/ their part. Point was taken long ago. I’ve never even removed it from the timing plate. There’s no reason to.Great thread. Jim's advice about not over inserting the brass oiler nipple on the cam gears is worth pointing out to the assembler.
I have your list, no biggie to send again. Do you recall the lifters having a peak? I’m really only curious at this point. I don’t plan on buying new lifters or a cam.I did get new lifters and a new melling cam. My cam was completely flat tho. I’ll send you my spreadsheet if I put it in drop box the last time we talked. I had money to spend at the time. I don’t remember either being crazy expensive but every dollar adds up when you don’t have money (my current situation so I’m oh so familiar).
New lifters are not flat they wear in thats why you don't mix match lifters when reassemblingI have your list, no biggie to send again. Do you recall the lifters having a peak? I’m really only curious at this point. I don’t plan on buying new lifters or a cam.
I agree if it was me i would replace the lifters and camshaft i do also know your on a budget but now is the time maybe hold off on reassembly until ypu can afford a new cam and lifters not sure if you are getting the shop to install it knowing you i doubt it lolYou can get reground lifters and new American (melling) Cam for about $250-ish. New Joint Fuji lifters (OEM) are about $16 each.
Ask your machinist about the regrounds. You're doing all this work kinda wrong place to budget since cam and lifters are known wear spots with modern low-zddp oils...
It wouldn’t be oem. Most likely Melling or whatever that brand is.aren't OEM camshafts kind of scarce?
Read a bunch a bit ago and was again reading the last page this AM before work. It got me doing some research on regrinding my lifters but I presume if I do that then I’ll need to do the cam too. Another person just suggested I buy one lifter, compare it to mine then provide it to a local shop to go by. Idk, I can’t rush any of this, too poor.The first page of this thread has some really good cam info on it. The rest is me problem solving fuel issues.
2FE Build Opinions Needed
I have started my 2FE build to go into an '84 FJ 60. The truck was purchased with motor issues which turned out to be a busted ring banging around in the #5 cylinder. I found a 3FE in Steamboat Springs with almost everything with it.(Including a set of mandrel bent headers which I will use)...forum.ih8mud.com
