FWIW I found a guy that makes a port match billet drain that seems to help stop oil backing up.
From my conversations with Borg it’s likely due to the drain not flowing enough causing it to back up and flow through the journal bearing seals.
Still get 0 oil in my radium catch can on the PCV minus a light film.
I replaced my drain fitting and switched to a stainless flex AN10 end drain hose.
Drain fitting
So far it seems happier. I also moved to a 7 layer Grimmspeed flange gasket which helped seal up the turbo to J pipe.
View attachment 4048814View attachment 4048815
Heatshield products form fit heat shielding has worked great so far on the exhaust components for heat management as well.
