Interesting. I had one fail one me that was old and figured it was just worn out.Found a boost leak location - EGR Vacuum Modulator Valve
A lot of guys are probably not running their EGR valve, but, if you are, the Vacuum Modulator Valve is a potential boost leak location.
A few weeks back I noticed getting on the freeway that I was not hitting 10 PSI boost when I railed it. Got out the Amazon smoke machine and found smoke pouring out of the EGR Vacuum Modulator Valve. Looks like I blew that thing open with the higher boost.
I picked up three check valves and installed them on the vacuum lines. No more smoke comes out, and I am hitting max boost just like before.
If you find you are not hitting the boost you think you should be, smoke the engine and pay attention to the Vacuum Modulator Valve.
Mike
If if your vacuum lines are holding and you still lack the boost, look at the exhaust system…mine was a new OEM system maybe 4 years old and restricted boost like you wouldn’t believe..custom 3” from the down pipe back got me all the boost I had paid forFound a boost leak location - EGR Vacuum Modulator Valve
Mike
Just following up on this in case its helpful for anybody in the future.I'm currently running an innovate SCG-1 for boost control/wideband (subject to change as I move to a standalone) but currently running a 4psi spring and a 3 port solenoid.
Light boost/part pedal I see around 3-5psi
I have boost control set to 7psi (easily achievable above 2400rpm with heavy pedal)
Truck is 160k, but its a fresh (ish) build ~5000mi on a brand new OEM shortblock and I went though the head/had it cleaned up. MLS headgasket, arp studs, kelford valve springs. Injectors were reman units with the new engine, new fuel pump, fuel filter, pressure regulator, etc all at the same time.
As @scottryana mentioned I am probably also struggling due to current temps here (single digits) making the air extra dense.
You beat me to my own reply about that bracket.Yes, there's a metal bracket that joins them together (should be bronze/silver). You can see it in my photo to the lower right of red circle, but i chopped it down in size and painted black.
Looks like your MAF was rotated 180 degrees to accomodate the wiring harness. It's a tight fit between the intake elbow, but it does barely fit.You beat me to my own reply about that bracket.
It doesn’t look like that bracket would work on mine since the MAF is turned around?
Hard to tell if you chopped that bracket.
If anyone can confirm, that should be easy to locate & cheap.
But I don’t want to buy the bracket if it won’t fit my current MAF orientation.
Also looks like I’m missing a bronze-colored bolt insert…
Either custom bracket or find the OEM and rotate MAF. One note, my MAF sensor housing (black rectangular box) makes contact with the under hood lining in this orientation.Am I going to have a make a custom bracket, or will the OEM bracket fit if the MAF is 180 degrees out?
