15w40 will flow better than 20w50 at low temps....so if you don't want the oil to flow as well, use the 20w50.
i buy whatevers cheap.
Howdy! It doesn't make a lot of difference on the viscosity unless your in sub zero or 100+ weather a lot. Any name brand oil should work pretty good, just stay away from the generic stuff. I learned that one the hard way. The most important thing is to change it on a regular basis. If it looks bad, then change it again, till it stays decent looking for 3-5M miles. Johnboth are excellent oils..
It is up to you. Neither one will show much difference.
Cruisers will run on wesson oil..
<Self moderated comment about changing the oil in the neighbors Cat.>don't remember what chemical it is, but rotella has something in it that will kill cats faster, so if you have a cat, don't use it. it is designed for diesels (as mentioned above). i use valvoline 20w50, but i've heard good about the castrol too. as long as you don't use penzoil or store brand recycled stuff, you should be good.
Valvoline 20-50 in the '40. Full synthetic in the FJC.
All the wrenches I know HATE Penzoil................why is that?
Ed
Ed
