What is this above my steering column? It looks to be a on the column shifter but it also has 4 on the floor. It will lock into place but I am afraid to do anything with it. Did they make fjs with both shifters?
What year is your cruiser?
Just a guess but with a lower padded dash and what looks like a choke and hand throttle on the dash it would be a 68 or 69. Not sure if the 3/69 to 9/69 two barrel hand a hand throttle but the earlier one barrel did.
I was going by what the title said but it could be wrong. I do have the choke on the dash.
Edit. Lower knob looks like a wiper switch. Believe 71 had a brake light switch to the left of the speedometer cluster. 1970?
I believe all 40's were three on the tree until '75 when the four speed was introduced.
Floor shift was a option back when the FJ40 was first introduced. 72 it seems a floor shift was standard. Early in the 74 model the three speed was replaced with a four speed.
At this rate it should be a 6 speed soon...
I was contemplating mission-creep..
The FJC 6 speed is not all that good in any event. Any transmission that incorporates the release bearing collar sleeve as part of the main housing can't be all that well thought out..
