Yeah thats just as far as we got. Needed a little clearance for the wheels to be able to roll it out of the shop.
Went to Poor Wally's to help out with my tub. Eventually the whole tub will be replaced with 1/8" steel behind the cowl.
I know it was asked before but could you show detailed pics of how you did it?
Here is what I watched to figure out how to install the twist locks:
http://www.youtube.com/watch?v=yad6QvCIkYY
I just used the razor blade and soldering iron method. Worked great.
I spaced the twist locks 1 3/4, 8 3/8, 15, 21 3/4, 28 3/8, 35 inches from the back of the Bpillar behind the doors. Only thing is I may add one more after the first one if the material doesn't shrink.
I bought the twist locks and footman loops from odcloth.com. I am sure there are cheaper versions out there at a marine store but they are high quality.
Here are some pictures of the L channel that I used to avoid drilling into the tub. it is 1" L that is 1/16 thick. A bit thinner than I would like but seems to be working. I cut it the width to span all of the tub holes and attached the twist locks then lined up to cut canvas.
Thanks for the detail. Is that L channel aluminum or steel?
I chose Aluminum but steel would work as well. Just longer drilling..![]()
oregonfj said:Got the rebuilt motor installed and took it for a test drive. Amazing power and torque difference with the higher compression, re-ground cam, and troll hole carb! No need for a V8 in this rig.
Did something I've been dreaming about for 2+ years: drive my own 40 to work and back on a beautiful day.![]()
Where did you get the flexible air hose for the air cleaner assembly?
