What have you done to your Land Cruiser this week? (38 Viewers)
Hi all,
There is a How to thread on Mud somewhere that shows the install of a 60 series PS and Steering column.
Im really interested in the steering column part of the install. so If anyone knows where it is please post a link!
Thanks.
Dialing in the engine/trans/TC location. Also the initial check fit of the gas tank. Still won't let me upload any more pictures....
Go to your account and disable Flash uploads in your preferences, then you'll be able to upload pics.
Thanks!!! Here's the picture... 12390952_1040185296003007_4109519569830087935_n.webp
Up sized the 4+ Cooler holder to the Yeti 45qt. And mounted my Hi-Lift. And secured everything with a cable lock so nothing grows feet....
Finally got the front heater blower motor resistor installed, aside from having to reposition the brackets it was fun. Got the housing all cleaned up, steel wooled and ready for some primer and paint. Excited that the bench test resulted in the return of both speeds. Hoping that the rear heater switch will work now that the primary switch should fire in both positions.
Found a donor 3speed transmission and t-case on Ebay Christmas morning for $100! Hope its salvageable. Not sure what I'm going to do with it or when, but figured it was a good price.
Well Happy New Year Folks
Peace
I taped the inside of my horn button so it doesn't rattle when I let it warm up in the morning
I put new wheel bearing seals in and replaced the star tab washer things for the bearing adjustment on the front wheels.
Probably gonna work on rigging up a hand throttle today with a bike shifter from work.
I'd like to see how you managed the throttle control via shifter, I was thinking the same thing, STI? Friction? Whats your thoughts?
Thanks
Garrett
Thanks
Garrett
I found THIS (< $36 with free shipping) hand throttle all I needed... mounts where you want it... I mounted it on the gear shift... ran the cable thru the firewall on the passenger side, then over the valve cover and directly to the bellcrank on carb linkage.
Thanks 77 wagon and Lost Marbles
But its still none of those.
Im still looking for the thread where someone fits a full 60 series steering column and height adjuster to a 40 series? anyone know it?
I don't know what you mean by 'adjuster'... try this one 60 series steering column into a 40
That is pretty genius!, did you run bicycle shift cable and housing or did you fab something else? Hmmmm, I'm going to have to take a look at what I can use, my 71 has the dash mounted knob but the housing and cable where cut by PO's. The versatility of your setup is nice.
:cheers:
Garrett
