FrazzledHunter
I tried to get those front fittings rotated as well but as I mentioned earlier in this thread I finally gave up and bought a needle grease fitting.Preventive maintenance on the new-to-me (last Friday) '13 LC.
FIrst, lubed the upper control arms per Slee for the OME BP51s that PO installed. Was told to do this twice a year. Seemed bone dry as it took a lot of handle squeezes to load 'em up.
Next, lubed the all six points on the front & back drive shaft. Two questions here - 1) anyone know an easier way to rotate the fittings so that the grease gun can get to? Tried neutral with parking brake on but couldn't rotate front or back shaft by hand. Had to move the LC forward a bit. 2) Is there an easier way to get the grease gun to release from the fitting? Got 'em all off but was afraid I was going to break a couple.
Lastly, checked the KDSS valves. My LC has been a CO vehicle its whole life, but you can see the rust...not that bad though. Was able to unscrew each valve a couple turns after PB blasting them. Dremeled off the rust, worked in some anti-seize and lathered it all up with marine grease. Before and after pics below.
Got all y'all from this forum to thank for the tips to do all this. Now I know it was done right and when.
View attachment 2398691View attachment 2398693
REF: What have you done to your 200 Series this week?
Using the needle made the job a snap - it's much more forgiving in terms of how you need to position the shafts.
I did the U-joint lube on my 2018 LC with barely 7000 miles on it. This might sound stupid and initially I thought it might be as well. However, I found the joints to be quite dry requiring 2-3 pumps from a full sized Alemite grease gun before any grease was pushed out. I repeat: my joints were DRY as far as I was concerned. I obviously have no idea how other LC's fare; perhaps I was just lucky LOL.
Note I got to where I am, lubing new cars & trucks, when on the advice of a mechanic friend I pulled both the diff covers of my new 1985 Chevy Blazer just after the break-in period. What I found was metal flakes/shards fall out of both of them. I did the same thing on my 2000 100 series LC but paid someone to do the diff dumps & U joint lubes etc... The mechanic that did that reported not seeing anything. Now a 2018 Toyota LC does not equal a 1985 Chevy Blazer. However, I think I've seen somewhere on this forum where someone examined an oil filter out of a newish LC and found small metal flakes in the paper. So I'm thinkin' paranoia is the best policy.
Needle lube grease fitting:
