What have you done to your 100 Series this week? (28 Viewers)
Took the kids camping...
Since my A/C condenser drip line has caused my front stabilizer bar mount and hardware to rust, I figured I’d just replace both sides with new OEM parts. My Cruiser Garage extension kit is already in place.
Question: Can I leave the LC parked on flat ground and simply swap the bracket and hardware one side at a time? Or do I need to raise the vehicle, etc.?
Also, is there an upgraded polyurethane bushing you recommend? I don’t know what the thickness of my factory bar is 🤷🏻
You should do the swap on the ground with the truck level. if the truck is on uneven ground the sway bar is under torsion.
I thought my right rear and left front speakers were blown because they made no sound. Got around to swapping the rears this afternoon and it still didn't work once I swapped it. I started jacking with the door and speaker started magically working. Turns out the wire was broken inside the little rubber boot. I just ran a couple feet of bypass and the speakers are working again. Guess I didn't need the new speakers after all. Anyone else have that happen? The front left speakers also had a broken wire.
Yeah. And when the plastichrome gets old and worn and flakes it will make a beeline to get under your fingernail and hurt you.
Ahhh yes - chrome door handles and nails. Anything else I need to know about the LX crowd?;)
Installed a pair of Road Safe front recovery points from Marks4wd in Aussieland. These fit like a glove in the ARB bumper mounts. I previously had a set of shackle mounts (similar to the trail tailor) and while they worked when the 100 was stock, they did not hang down far enough with the ARB bumper brackets to install a shackle.
I then gave the living components a once over before we head to the Rockies.
...and yes, I need to spray the driveway :oops:
Do you have link for these?
