What have you done to your 100 Series this week? (54 Viewers)
white knuckles arrived
Did you put that sticker on the slider? Or they did? And how hard was the installed? I should be receiving mine in about two weeks.
they had the stickers on when they arrived. installation was very easy. I just have to check the brakelines again to make sure there is not rubbing with the slider bolts
KC HiLites 2" C-Series C2 LED Area Flood Lights!! Hooked up to the switchpro. Rear lights are on 1 circuit, side lights are on another. Cool party trick that I can turn them on from inside the house with my cell phone. :cool:
Replaced rear OEM shocks with iron Man form cells. Easy job but wasted about 30mins because they came with 13/16 top nut . Had to reuse OEM 22mm nut. I don't want to mix those up
I have some major things coming in the next couple weeks. New steering rack and hoses, rotors, brake pads, etc. So, to kill some time this weekend I worked on some cosmetics. My front grill is beat up pretty bad from rock chips, so cleaned it up with some plasti dip. Also, I shamelessly completely copied @ikarus in regards to the RAM mount. I was at a loss for phone storage and that solution was perfect.
Before:
02RgnQVkzq8yc-9CpuTJ6rv2mEegZ78nL6SajfEkebniniJTzez-Atm0Wy2YQBWwVMREoy08Ks-Z44-LjtyIkGpLH0wDHjR5cxz_DLadH0AkESwfrVwJIfXEzJBMXZ_Ezy_b4fa4-tqJ-h70EjpRzvSTlg_CzBNgXLNGwQgwFLaurqccUdEd4vC6q5-d6-_1l7rgM1w2mU8fP_RgqSz_rIOOdb3xux_QVMeWV6whQsHU3llYqLe4J9CL9R-1-qQP8YUIIfrjCaebUCrzXV-byN3aPtN6U7ilwOzpjfL4WA0IFp8tJMW6VrTnTIrp3KVu0rLwKyxG8SAgfjw4aLYwyQpvOMP9T38FZvO6TqqTPjuLAUDe-0iPQDDG89BTsZ9dcmlgGaCsRHeKO3zEELEO3WNboc6_-wX-kLeiMNxlcHay5qPf3sHN1mKvAJZRGzEOOBJSP8BEtjS8669M5Z8MemZqGkOYCGjIalpfz_nvkudmT85qVRvtw5UGgm3PUIYHOxvUqEMsMvbtHDUy4GmSC7A_DUQ1l3xDwKvvE6yaKn_Qk2C7Mu6ODRst5nbS928lbYPaSEX0RlqUT0cmOzpM2q8k8ut44A_cn_yI9suh=w1155-h804-no
After:
PAUWG14JEIL9a2ZybDCWTXV3Zh9J5XB2p_unyjfPnth4Ovu7uXKAuxS5YmRAIhFW_RzkCFSvKESH_1lMwi3P3FwnP3tEw_dkPcbi7N9FmzHqTfmMg-ogKjrDdszucEpDBsFQSFFeXIzuwctJmrnXFyml_sVONDgqAuM-eqMpqzXBCUajYRecsZTMGazHnvfKPsT6D7U24Z2TBmgw-JhJtU8qTlsPgduruT-Q-q8rUP3-19GlnPRn4F8bifkSqAydaMsCO20GwepMogCRZ1uiQYOTpJ1fkgO3nv7gg1BZ7FN-MxQQvPD5qsGi4ZRj1jGkIEF0wHIJgGpt1ktecxK3gYJ-sqmSznHED9EdpwPB-I577azRnm2qEizLt6M2VGbYM8ybp0xMsO_pTojnYAZB83Wi7zw_1mtA0gA3Tnx-kjjqChIX9y0kC-dbsbhFfQJg4INdCrzWs69KqngGX2mvB_jtWkExrt4hRAVglMOIj5eDviQyThPHqmCTpGfP5EJqVJNnQQK0Y9A0wuEtrOhHYITakZZOB1I5upmF0ySsfMFAAjuaDkR_PdFa9ZP9tw7xyMPjxg5XqMuNEZ9bCo5vNzo37hu9kLfLsdmb0ezz=w1733-h1299-no
RAM Mount:
VGuQMU7oy8WQloyDgEhVp5smt5MQi8m0Nzot_fp5VDM_u8_jpib33XI0rH3sdxRkAvm3uibI_1dhHrTv_k1n4ncIUacZ_Mpq8q4JUp6QWK0u2EuKemOl3BT9SLDWf9JTtO-zd-Pj1kpTAfnrNALYBBQ4PW3dJaUaSKuvyXumJZE0xYEKUZzTk0hlSQZWappXTkzNZQ--y_c-0K6iMSuo3Rqh0wPNfdGNJVRs17JvIGwKpRg9zNCOkxXCbBxgoJcYLRVA_89zFa_UybJcEHPUshibSzsW0VG7keIIVsvklkLgIap4CDCfsZS7HELGZ-I7yMA51rLlzL2VbCttmkRoGGc5l--jimPWtQCxmqS0LNQd3TO1LAWMuA0YeMJB0a6JhnuXomivCKzhZ9lh0k3yuTjBmWHWhyaJMoMcy684syfbcEPsqJb3w2BZlYBygMB5aXaTC2pWMBQShnmKTiyBM3WB8HXSIpjpZn1w5NDDjIksr_3tJ7IixXGnIzyfY83G9Gdl1D2t53RAEb-meQBNCp5-TsRFx0R7eZokt2n6RMhbr0Y9kkciya1qPFCwACqSuEDVe5V8IP2kEb9HSdzb8LWfX1GTEcRNuv7ueuuS=w975-h1299-no
znX3qcbxiorF29-ngTVPKzMkek_SRY-uXQLe_eZ1Bls0QQsZ2AtJ5ej7bGD_wIC5WonYUmwTKZt5pyNZLx9C_ihHcpo71ilGgIgFKDLB7WBVi6tt6tHZZollr437MfpzeZI8qdcogBmP_1B9RAOg_VDnKN9qpwqtgJEpz2iZYjvZ-Vhpf6GDFjsmI3--3w6SR5v4swHh9VFwt2s9JjUTzPwDb5kuAei1ZM6nOwLhCR5piyglGAtrbFsqlEdllgIxkXKJ9MgjcvNlQAihmK_axQwP4uwroibl6PpG_HW2iowZpV-z5GQwKLxIM4-JActinfFMFuxbF4TxMQ3B53uwPmQmPO-Mqw9T2V72q77i4hynw8mD9LF3mZPxLihd-CP2TZQC5CgcutF0cl2jToZrMt7vrdj8Boy_KdGBZOXL67-jbtDEn07-T39j2cwTC9Dm8l5SD2X0u-28rMashvdeOS_ktkunrCPCvJzgudZrYaJMS5hwjliv-grD7lsKZc32Cbfbpmh2jFdt41p-byEO5-dfgKbBWFv9CKe2f4qO-FsYm7NJX2vD1V4Ir3sYvzQP6TMFTzO3OME1iTmZRWeiNdAyl0Cr6DD_ibCRWbQG=w975-h1299-no
Before:
After:
RAM Mount:
love the ram mount and want to be a copy cat too....do you have a link to order one?
Spent some time on paint today. PO had hard water stains from sprinklers that I hadn't taken the time to get rid of yet. Claybar, 3m rubbing compound and some wax later..... paint is clear and buttery smooth.
Also realized I haven't posted an updated pic with the 285 ko2s instead of stock tires.
Test fit an ammo can for under hood storage. Had this left over from my last LC. Not my original idea, someone mentioned it in a post on this forum long ago. I'll shoot it with some trim paint before I make it semi-permanent. Had jumper cables in it last time and worked well, but it is a tight fit.
Also installed new front recovery points from trail tailor
Xena was a little dirty, so I drove through mother nature's car wash. If was not very effective.
