What have you done to your 100 Series this week? (40 Viewers)
Snorkel looks awesome! Truck looks awesome! If you don't mind me asking, what did you use to paint your grill? Looks good from this angle…mind posting up a full-frontal picture? Is she okay with that?
Thank!! Not paint - plastidip. And has held up well. Color is Anthracite Gray and matches the gray lower body color in a lot of our trucks. Followed up with a “glossifier” coat. Very easy to do. All on YouTube.
Rear new rotors, pads, and calipers.
Yea, 3 days before Christmas!
Check those pads before they go metal on metal.
Where did you relocate the control module to for the winch? The install looks really clean. I am working towards figuring out where to put the control module on my VR-10 S winch. I was thinking about putting it where you have the light bar. Ha ha, but I want to mount a light bar exactly where you did.
I wouldn’t say this is optimal - but it works. I have it tucked in against the center cross member with a zip tie to keep it from shifting. It’s in pretty tight. The end state intent is to fab up a bracket to keep it tight - but this is working for now ...
View attachment 1596694 View attachment 1596695 View attachment 1596696
You might try and mount that to radiator brace where the upper horn is mounted. Make some L brackets and use the various threaded holes available on the brace to mount to.
Be carful to not let that rub on your cooling fins too long.
My house battery was not holding a charge so I swapped out a very expensive Die Hard Platinum marine battery for a not so expensive Duracell marine battery.
If this doesn’t work I’m throwing my National Luna split charging system in the trash.
New plates and new tundra wheels powder coated Bronze wheels with 35” ko2’s . I need to find a better color match for the center caps, but not bad for now. Ps. My Cooper STT Pro are for sale in the classifieds. Only 6k miles on them.
Awesome. Thank you for posting up those photos. I believe that I am going to get the long relocation kit and move the module to where I have some extra room around the primary battery. Your setup definitely gives me food for thought though...
@jno not yet. Not at all around town. I’m sure I will a little during offroading / rock crawling, But I had previously done some pinch weld trimming and I am also running 1.25”.
  • Like
Reactions: jno
Any feedback on the STT Pros vs K02 street handling and road noise. Im actually leaning toward this tire and offing my K02s.
Probably the best characteristic about my 100 is the almost rust-free undercarriage...a huge contrast from the local 100s for sale here in the mid-Atlantic which were almost all rusted to hell.
So I picked up a gallon of Fluid Film and used a cheap $30 spray gun and my old 5 gallon air compressor. I used a little over half gallon and applied this stuff liberally. So glad I didn’t go with the spray cans. I have enough to do another application. If I could do it all over, I’d heat up the can before spraying. It’s very likely I’d have used less. I’d also pick up one of those flexible hose nozzles to get into the hard to reach places. I ended up applying by hand on some parts.
Your wheels look great.
I know it sounds corny, but try putting down a wet coat of your bronze spray paint (looks too light in the picture, right?), then when it flashes for just a few seconds but it is still wet enough for another coat to "burn in", dust it with black spray or even better a bronze that is darker. Dust it til it looks right and you should have it. It did a similar deal with my "grey chrome" wheels and it worked great.
I liked my STT Pro a lot. My only complaint is that the white letters didn’t clean up as easy as BFG’s. Otherwise it’s a great tire. I have ran them for 6k miles and they still look brand new. My wife didn’t care for the pro look. Was just an opportunity to eat new tires again. I had to
