What have you done to your 100 Series this week? (19 Viewers)
I finally had the duiser 1” body lift and arb diff breather I had in my garage for the past 6 months installed by Tandem Automotive of Fort Worth. The blue hose I used was sourced from a vendor my company uses in the oil and gas industry. The arb kit only came with 25ft of tubing. I have plenty of it left if anyone needs any.
Saw
Want some if you still got it. The tubing that is
I'm very impressed with the Dynamat stuff, heavy sure, expensive Yeah, but the blend of materials is brilliant and actually not that hard to apply (I have gotten a few small cut in my hands do to the aluminum uppermost layer but no big deal)
Now I'm thinking of installing some on the front edge of the roof to diminish aerodynamic noise, but coming from a Range Rover classic I don't want my liner to sag
Is it a way to do it "right"..??
Three years ago today this Land Cruiser joined our family. Happy birthday, Gojira!
12 gallons of distilled water and a whole afternoon later, I flushed out all of the NAPA green stuff from the cooling system. Filled back up with the beautiful blood red Toyota super long life.
Which product did you use?
Thickness?
No idea but I check my amazon cart and take a picture of the box in the morning
The plastic cover s are no t even on and the truck is already much quieter, expensive endive but very happy with the results
DOH tip.. if you leave the sheets in the sun or even inside the truck ona hot day they become a little more stretchy and pliable, making it even easier to work..
How many gallons of coolant did you need to fill up the system after flushing? I need to do mine.
Dwight S is correct
Just over 4 gallons. 2 gallons of concentrated coolant and a little over 2 gallons of distilled water.
Front diff, rear diff and transfer case oil changed. I went with Lucas synthetic 75-90.
Installed my trailer brake controller with a 3040-p. Less than a 5 min job!
Got my suspension installed! Total chaos UCAs and OME medium all around.
^^ That guy should really wear at least a mask, can't imagine breathing in this stuff is good for you.
$150 Ebay LEDs tailight modified to make it look like an O6-07. I'm currently putting on a rear whale tale so that's why the rear looks like that. Weird lighting effect from photo but the red is the same shade, just the bulb inside made it look a little darker.
